Diablo help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-15-2018, 08:50 PM Thread Starter
bmeyers007's Avatar
Diablo help
Does anybody know who in the NY/NJ area can still tune or look at a Diablo chip? I can also send computer out if that is an option. I have a 91 Mustang with a Kenne Bell s/c and a old school Diablo chip. Car starts and runs great until I turn it off. When that happens with the key on engine off the fuel pump keeps priming and I can kind of get it to start but it is a mess. I can let it sit for a day and it will run perfectly again until the key is shut off and I try to start it again. I have changed the fuel pump relay under the seat and replaced the tfi module but no good. I pulled the computer and had the capacitors replaced which were bad but still no good. My only thought is possibly the tune is corrupt. The guy who did the capacitors said the tune is protected so he could not check if it was corrupt. Any help would be appreciated as I can't drive the car because if I shut it off I can't get it back home again.
Kenne Bell s/c @ 10lbs, 30# injectors, 255 in-tank, 90mm lmaf, 4" Anderson intake, Magnaflow exhaust, Diablo tune.
bmeyers007 is offline
post #2 of 5 Old 07-28-2018, 09:43 AM
indy2000's Avatar
have you looked at the fuel pump circuit on a wiring diagram?
indy2000 is offline
post #3 of 5 Old 08-16-2018, 04:35 PM Thread Starter
bmeyers007's Avatar
Sorry I just saw this. I did look at the wiring diagram. Thoughts?
post #4 of 5 Old 08-16-2018, 08:21 PM
indy2000's Avatar
you have two threads on this?
indy2000 is offline
post #5 of 5 Old 08-16-2018, 10:19 PM Thread Starter
bmeyers007's Avatar
Kind of. I was hoping to find a Diablo dealer with this thread who could look at my old Delta chip. Apparently the answer is nobody but I think I ruled the chip out at this point. I was trying to keep it separate so I could learn more tech from the other post. Thanks.
For Sale 03-04 Cobra Diablo Predator 1QWK96GT Electronics and Entertainment 2 06-16-2013 04:19 PM
For Sale Diablo chip for Mustang 289Notch Electronics and Entertainment 7 05-24-2012 05:21 PM
For Sale Diablo Multi-Program Switch Chip 1989 - 1995 ...like SCT Chip ICEMAN330824 Electronics and Entertainment 5 04-24-2012 02:25 PM
For Sale Granatelli motorsports Diablo predator u7146 with pc interface kit. (unlocked) go2sleep Electronics and Entertainment 1 10-06-2011 10:04 AM
diablo predator noob question brian97cobra Engine Management Systems 0 04-12-2011 10:32 PM
