Does this seem like a bad Hall Effect sensor? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-02-2018, 09:15 AM Thread Starter
jmardlin's Avatar
I am getting the code for erratic spark signal. If I disconnect the battery then hook it back up the car will start and run normally till I shut it off. Then if I try to start it it misses badly when it does try to run. If you use the gas pedal to try and keep it running it spark knocks also. It doesn't at all when it runs normally.
jmardlin is offline
post #2 of 2 Old 05-02-2018, 06:27 PM
Blown88GT's Avatar
Code 18?
Disconnecting battery resets ECU & all that it has adapted.
Ford EEC-IV/TFI-IV Electronic Engine Control Troubleshooting
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
1994 airbag impact sensor compatibility jhop 94/95 Tech 3 10-12-2015 04:51 PM
1989 mustang gt randomly shuts off five.zero General Mustang Tech 5 04-10-2013 10:49 PM
Oil light becoming frequent, maybe sensor isn't bad? 87gtconvert 5.0/5.8 Engine Tech 17 11-05-2012 04:52 PM
MAF Sensor Bad??? mw95gt Turbochargers 0 05-20-2011 06:43 AM
Intake Charge Tempature Sensor....do they go bad?? planefixer4 5.0/5.8 Engine Tech 6 12-02-2001 11:41 AM
