Bama 4-Bank eliminator chip for '86-'88 SD cars - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 04-09-2018, 07:01 AM Thread Starter
Nitrous Al's Avatar
Question Bama 4-Bank eliminator chip for '86-'88 SD cars
It's probably best to just convert my '88 GT to Mass Air. Any '86-'88 SD car owners using the Bama 4-Bank eliminator chip or something else? I just want a pump gas tune (87-93) and an E85 tune for my car. Basically make it a flex fuel car for the times E85 is available. There's an E85 pump not too far away, but I'm not going to drive there every time I need to fill up. Thanks!
'88 5.0 GT hatch AOD 3.08
stock 302, Ed Curtis cam & 11R 190 heads,
Holley SM2, 320 hp 332 tq to the wheels
Nitrous Al is offline
post #2 of 9 Old 04-15-2018, 01:41 PM
That really won't give you flex fuel capability, and being SD or MAF has nothing to do with what you have in mind.
Doing what you describe you'd also have to drain your tank and purge your lines every time you wanted to switch fuels.
If you want flex fuel you need to add an oxygen sensor to the fuel supply so it can measure exactly how much alcohol is in the fuel and then adjust your fuel delivery to compensate. A BAMA chip can't support that, you need a new ECU to do that.
A compromise would be to add a 2nd fuel tank just for E85. You would still need to purge lines which changing fuels but you wouldn't need to drain tanks, just turn valves to change your draw and return from one tank or the other. A BAMA chip could support this because it never needs to deal with some blend between the two fuels. But it's really important that you are anal about purging lines when switching fuels, you can't mix them or your tune is off.
Final thought, you won't make any more power on E85 than you will on pump gas without something like a turbocharger.
Megasquirt
seijirou is offline
post #3 of 9 Old 04-15-2018, 10:44 PM Thread Starter
Nitrous Al's Avatar
I'm putting my mass air conversion on hold for now. I'm not sure if I'm sticking with the 302 sbf. I'll do more research on E85 also.
I think your final thought is incorrect. Please watch the video below. The 2018 Mustang GT doesn't have a turbocharger.
post #4 of 9 Old 04-15-2018, 11:25 PM
Those have 12:1 compression, so yes with E85 there's power to be gained in more advanced timing. Unless you rebuild your engine for high compression you'll have nothing to gain. That's why I mean "something like" a turbocharger. Something that puts cylinder pressures high enough that you can't run minimum timing for best torque before creating pre-ignition. On an N/A 9:1 compression ratio small block ford you can make max power without even running 93 octane let alone the need for E85.
Megasquirt
seijirou is offline
post #5 of 9 Old 04-16-2018, 07:31 AM Thread Starter
Nitrous Al's Avatar
Thumbs up
I forgot about the compression ratio. Thank you for the info. I'm leaning towards the newer stuff (Mod motor or coyote) more and more. I'm not ruling out a turbocharger. I have a lot of decisions to make. I'm glad to didn't order the '86-'88 mass air kit $600+.
post #6 of 9 Old 04-16-2018, 09:49 AM
If I were starting fresh I'd do a Coyote.
Megasquirt
seijirou is offline
post #7 of 9 Old 04-16-2018, 08:18 PM Thread Starter
Nitrous Al's Avatar
They are expensive. Even if you go the junkyard engine route. You still need a ton of parts.
post #8 of 9 Old 04-17-2018, 09:16 AM
I haven't looked into it really, but you can get engine and trans with accessories and harness for $5k. Fab up a throttle cable, buy the swap headers and mounts, and in my situation I'd just hook up my megasquirt and go to town. I think it would be no more than building a "real" SBF, likely less.
But I don't think I could resist stroking it to 351 first, lol.
Megasquirt
seijirou is offline
post #9 of 9 Old 04-17-2018, 09:38 AM Thread Starter
Nitrous Al's Avatar
F150 coyotes are about $2500. After swapping the cams and oil pump gears, front accessories, one might be better off purchasing one brand new. I'm still doing the research.
Is tuning really not necessary for a bolt on car? 4rd Tough 94/95 Tech 67 01-27-2014 10:46 PM
For Sale 1990, 1991 AND 1991 Ford Mustang GT 5.0's, 5 speeds for sale, CA rust free cars!!! camustangperf Mustangs For Sale/Wanted, 1987-1993 0 11-14-2013 09:53 AM
Cars And Copters Returns To Plymouth Mass Airport September 15, 2013 RickyFrat Northeast 0 09-08-2013 09:50 PM
WE BUY CARS FOR CASH junkcarbuyer Drag Racing 2 06-20-2013 08:19 AM
bolt ons: BAMA 91 VS Custom 91 VS custom E85 Truebluedevil02 S-197 Mustang GT (2011-2014) 11 03-24-2013 04:48 PM
