MSPNP2 Fox too Sn95 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-24-2018, 08:34 PM Thread Starter
MSPNP2 Fox too Sn95
Is it possible to reconfigure either the harness or the ecu from a fox (mspnp2) too work with a SN95?
lxsmith2 is offline
post #2 of 2 Old 02-28-2018, 05:04 PM
Blown88GT's Avatar
https://www.diyautotune.com/support/...r-mustang-5-0/
On SN95 Mustangs, you can use the MegaSquirt to remove the stock ECU if you have a manual tranmsission. You only need to keep the stock ECU if you are running an automatic, since MegaSquirt (currently) does not have transmission control outputs.
https://www.diyautotune.com/product/...-manual-trans/
You'll have to ask DIYAutoTune if the 86-93 model can be reconfigured for the 94-95.
[email protected]
He answered your question here:
https://forums.corral.net/forums/mega...mustang-2.html
1988 GT, 57k mi, Orig Owner
Blown88GT is offline
Fox shocks on SN95. I think I goofed. fasterthangas General Mustang Tech 4 10-21-2017 02:41 PM
Widening SN95 wheels for use on Fox - How wide can you go? Mustang5L5 Wheels and Tires 7 09-08-2016 04:02 PM
Front anti-roll bar. Diff in Fox and SN95 az97cobra Road Racing/Auto X 7 01-14-2016 02:47 PM
Want To Trade 1988 Fox Coupe roller for SN95 Cobra/GT Roller Wicked03GT Other Fords and Trades 5 06-02-2013 10:26 PM
SN95 vs. Fox fuel tank Neighbors General Mustang Tech 2 09-18-2002 10:01 PM
