1993 Cobra EEC - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 11 Old 02-17-2018, 09:55 AM Thread Starter
vinnietbird's Avatar
Trader Feedback: (139)
1993 Cobra EEC
I run an ECM from a 93 Cobra in my Thunderbird and 24# injectors. If I want to go to 30# injectors, can I simply swap the injectors and use an aftermarket MAF for the 30's as if I was using an A9P or other ECM?
'88 Tbird..Z-Spec T-5,Track Heat intake,BBK CAI,Ed Curtis cam,Twisted Wedge heads,1.6 Scorpions,3G,Mass Air with 24's,75mm t-body,BBK CAI,140 mph speedo,8.8 with 3.73's,BBK shorties,mini starter,O/R H-Pipe, Flowmaster Super 44's, Saleen SC wheels,Taurus fan,CHE control arms
vinnietbird is offline
post #2 of 11 Old 02-17-2018, 02:16 PM
Paulie's Avatar
No. A calibrated MAF works by scaling its output by the ratio of the stock injectors the EEC was programmed for and the new larger injectors. On the non-cobras that ratio is 19/30. For your Cobra EEC the ratio is 24/30 so it will not work. I thought they made calibrated MAFS specifically for Cobras.
1990 LX, HCI, S-trim
Paulie is offline
post #3 of 11 Old 02-17-2018, 11:53 PM Thread Starter
I have the matching Cobra Mass Air meter on my car with 24# injectors. Was thinking about going to 30's.
post #4 of 11 Old 02-18-2018, 02:00 PM
Paulie's Avatar
Maybe I misunderstood your question. You can use a calibrated MAF. Just make sure it is calibrated for 30# injectors AND a Cobra computer.
Paulie is offline
post #5 of 11 Old 02-18-2018, 04:52 PM
have use what i call offset mafs not really the way to go. kida like a band aid when you need stitches
turbo2256b is offline
post #6 of 11 Old 02-18-2018, 11:49 PM Thread Starter
how much power are the 24# injectors good for?
post #7 of 11 Old 02-19-2018, 01:42 PM
2dxtrm is offline
post #8 of 11 Old 02-19-2018, 01:44 PM
A chart found in the Ford Racing Catalog....
2dxtrm is offline
post #9 of 11 Old 02-20-2018, 05:28 PM Thread Starter
Thanks for that graph. I appreciate that.
So if I bought 30# injectors, and a mass air meter for them, why wouldn't that work with the X3Z Cobra ECM ?
post #10 of 11 Old 02-20-2018, 06:00 PM
jmardlin's Avatar
It is hard to find MAF's for the X3Z. There are a couple though. The bigger problem is that when you use calibrated mafs it really messes it the load percentages as the engine thinks it is under less load (if it went to bigger injectors). This will cause the computer to advance the timing more than normal for the rpm and load which can cause issues or at worst major damage. It is better to get a tuner like a Quarterhorse and input the new injector parameters into the stock tune and refine it from there.
83 Capri RS T-Top 302, Afr 195 Renegade,11.2 compression, e303 cam, Scorpion 1.82 race series rockers, TFS-R, X3Z w/Tweecer RT, T56 Magnum, 2 1/2" Pypes X pipe w/2 chamber Flowmaster mufflers.
jmardlin is offline
post #11 of 11 Old 02-20-2018, 08:23 PM Thread Starter
Thanks for that information. I'll keep the X3Z and 24's at this time. I hope to dyno the car in the next couple of months after I install the new parts and see what the engine can do.
Craigslist removed my dating ad. Available ladies, read inside! stangPlus2Birds Lounge 20 10-14-2013 10:54 PM
I need your help with Ford Modular ¼ mile ET Quick list all time mobeydick Drag Racing 27 04-17-2013 02:53 PM
FORD RACING Cobra Jet Showdown Milan Dragway, Aug 24-26 nmrajefftaylor Mid-Atlantic 0 08-09-2012 11:11 AM
For Sale 96 Cobra Part Out bmwm3 Interior Parts 24 07-12-2012 08:51 AM
First Cobra, gotta a stupid question JP_Stang SVT & DOHC 4 05-20-2011 07:48 PM
