1994 Mustang Cobra stand-alone selection help - Ford Mustang Forums : Corral.net Mustang Forum
 4Likes
post #1 of 15 Old 02-04-2018, 11:07 AM Thread Starter
machine head's Avatar
I have a 1994 Cobra Mustang 306 H/C/I car. Iíve had my car dyno tuned but car still has issues. Im tired of paying for someone to tune my car. I really HATE the 1994 Mustang ecu. I want to run a stand-alone system. My question is: Whatís the easiest to install plug-n-play style? Mega Squirt, Holley Dominator, Holley Sniper, F.A.S.T ez 2.0.
Iím not computer savvy so I want what ever is the easiest to tune SELF TUNING would be preferred
Thank you.
94' Mustang Cobra #2524
1 of 333 Rio Red w/ Black interiorēFORSALEē
color="black">MOTORCYCLE DRAG RACING LOWERING STRAPS & CALIPER BRACKETS
machine head is offline
post #2 of 15 Old 02-04-2018, 04:08 PM
castine917's Avatar
The Holley is nice in what it can do but, not exactly plug and play.
95gt 363,67camaro,79 firebird, 05sti,94yukon,91boxekee,98formula,yada,yada,yada,. ....
castine917 is offline
post #3 of 15 Old 02-05-2018, 06:41 AM
Administrator
Greg@GLD's Avatar
Lightbulb
Yup.
It just so happens that I have a '94 Cobra and am running Megasquirt with that car and I don't have a bad thing to say about that system, however I am doing a 1992 GT build currently and am running the Holley HP system. As was stated, it's NOT plug-and-play, but at the same time it's also very easy to work with and install. For the OP however, it is worth noting that you can get a MS3 system where the EEC plugs right into your factory harness. Just keep in mind that the wiring on your Cobra is over 2 decades old. There's a lot of support for Megasquirt, but I would say if you are totally new to tuning, you **may** find the Holley is more friendly to the first-time "self tuner" who wants to learn and break away from depending on someone else to tune his/her car... The "help" functions in the software are outstanding.
castine917 likes this.
post #4 of 15 Old 02-12-2018, 09:47 AM
This question has a very easy to answer solution. If you've researched much at all, I think you will find that the Pro-M is the closest thing to plug and play you're going to find. That is precisely what led me in that direction, I'm quite pleased with the results.
Jay
thadude likes this.
petmotel is offline
post #5 of 15 Old 02-12-2018, 12:50 PM
Thank you.
Have a look at the MegaSquirt PNP installation instructions for what it takes to install one:
MegaSquirtPNP by DIYAutoTune.com
You would need to add a wideband O2 sensor for the Tune Analyze Live feature, but that's typically just three or four wires.
Matt Cramer
Matt Cramer is offline
post #6 of 15 Old 02-14-2018, 04:30 AM
thadude's Avatar
Pro-M hands down, read the thread on the system it has some great reviews.
thadude is offline
post #7 of 15 Old 02-14-2018, 10:13 AM
indy2000's Avatar
Thank you.
there is no self learning, you need to realize that
its an over used term that will give you a false sense of outcome
looking at exhaust 02 content and running a PID around the commanded fuel mass is not self learning.
tuning is that, tuning
requires time and patience, as no 2 setups are exact
if you have any type of mechanical deficiency, forget about it
there is NO plug and play, another 'bolt on" useless saying
if you are not computer savvy, you will need to pay someone who is.
pkstang likes this.
indy2000 is offline
post #8 of 15 Old 04-11-2018, 04:10 PM
Nitrous Al's Avatar
Question
I assume the Pro-M system works with a mass air conversion kit if your car was previously a '86-'88 speed density car?
'88 5.0 GT hatch AOD 3.08
stock 302, Ed Curtis cam & 11R 190 heads,
Holley SM2, 320 hp 332 tq to the wheels
Nitrous Al is offline
post #9 of 15 Old 04-12-2018, 11:09 AM
You're simply, and categorically wrong! I have a '95 with a serious road course 363 (solid roller, 11:1, single plane, 1000 cfm throttle body, throttle body mounted MAF sensor, 42lb. injectors, AFR heads) with a Pro-M ECU. It runs great, and street manners are very good even with the solid roller.
Just a very few variables need to be input into the software for this system to operate well (engine displacement, high and low injector values, MAF transfer function, oxygen sensor type (wideband, or not), and idle speed. Anyone can make this work well, no tuning knowledge required. In fact, the unit can be ordered with the variables already input for a few extra bucks. That leaves the end user to set the base timing, adjust the throttle body for idle speed, and check the low slope injector value.
Until you are familiarized with this system, you should really resist the temptation to make incorrect blanket statements, but I know that is highly unlikely. If you can find someone in your area using a Pro-M system, check it out, maybe even you can learn a thing or two.
Jay
petmotel is offline
post #10 of 15 Old 04-12-2018, 11:39 PM
indy2000's Avatar
am not
and I am quite aware of the capability of said product.
but hang on to the myth,,,,,,and pass it around.
indy2000 is offline
post #11 of 15 Old 04-13-2018, 10:43 AM
am not
In denial much? Have a nice Friday 13th!
Jay
petmotel is offline
post #12 of 15 Old 04-14-2018, 03:28 PM
FWIW TunerStudio's autotune is a little more than this. It might be PID driven, certainly there's some algorithm applied, but the output of the equation is written back to the fuel table (not trim tables, the actual fuel table) so the update is permanent. Through finite iterations it will bring the fuel onto target.
Megasquirt
seijirou is offline
post #13 of 15 Old 04-14-2018, 07:05 PM
indy2000's Avatar
that is really nice to know.
still not self learning.
indy2000 is offline
post #14 of 15 Old 04-15-2018, 11:23 AM
Autotune is great. I have used autotune for my megasquirt system tuning. But in my experience it will not work as intended unless your tune is already close. And unfortunately getting it close requires tuning. So IMO it is a tuning aid not a replacement for tuning.
How many people over the years have assumed that an A9L 5.0 with a cam, intake and heads. Maybe some 30lb injectors with what they think is the proper MAF....... Just to run like crap.... But isn't it self learning? It has 02 sensors doesn't it? I'm sure these newer systems are better but still... Change your 30lb injectors out for some 80's without tuning? Sorry but it isn't going to "self learn".
bender4601 is offline
post #15 of 15 Old 04-15-2018, 01:32 PM
For what the OP is looking for, many (if not all) aftermarket ECU solutions today will tune their own fuel tables to some target under static conditions.
I've used one that will even tune the ignition by itself, but it uses knock sensing to do so which is not the right way to tune ignition. It also requires ion sensing in the ignition system.
OP what you aren't going to find is a solution that will also tune in the transients. Things like acceleration enrichment and enleanment that really make the difference between a car that run WOT down the track and one that is also pleasant to drive on the street.
Like bender said, these functionalities are aids / time savers. They can knock out the easy stuff for you very quickly but they're still leaving the hard stuff in your lap. If you're thinking that they're going to save you from the hard stuff you're not going to be happy.
MadViking likes this.
Megasquirt
seijirou is offline
For Sale Ping 96 Cobra and much more!! OHIO Jeepman1 Miscellaneous Mustang Parts 8 08-10-2017 09:25 PM
For Sale 1994 Mustang GT Supercharged (Cobra Clone) YouEnvyMe Mustangs For Sale/Wanted, 1994-1998 0 05-05-2017 05:56 PM
I need your help with Ford Modular ¬ľ mile ET Quick list all time mobeydick Drag Racing 27 04-17-2013 02:53 PM
