Issues: Moates QH issues on my K.B. foxbody - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 01-14-2018, 07:14 PM Thread Starter
91 coupe 5.0
5 speed
A9l
Kenne Bell 1.5 5psi
Moates qh and BE
42lb injector
Walboro 255 lph
C&l MAF housing (42lb) and tb elbow
70MM Tb
I just installed the above parts at once and have been dealing with issues idling and drivability. At first the fuel pump wouldn’t stop priming. Figured out it there was some residue of protectant on the j3 port. After cleaning that off the fuel pump functioned normally.
Currently, I’m seeing on a cold start the AFR at about 14.5. Once the car starts to idle down the AFR goes up to 10.0 at idle. Car runs terrible aand won’t hold idle. It starts surging. Reading is on an AEM wideband not on the BE.
Once the car isles down and has been running. I give it gas while sitting and AFR drops to 14.5.
I have a base tune I burned to the chip. Tune was provided by Chris at PAS. I’m sure he will build me another tune for base. But unfortunately they’re closed. Thinking this could just be a corrupt tune.
Tomorrow I plan to burn a new tune and see where that gets me.
Any suggestions in the meantime? I ran the car before without a 6 al installed and just installed one. But AFR is still the same.
TurboCoupe1 is offline
post #2 of 4 Old 01-14-2018, 07:20 PM
Trader Feedback: (21)
What's you maf curve look like? Also what's your ECM demanding for lambda vs your actual lambses?
For everything that is worthwhile, there is a counterfeit.
boostup89 is online now
post #3 of 4 Old 01-15-2018, 09:38 AM Thread Starter
Lambse1 12.077 same as 2
post #4 of 4 Old 01-15-2018, 11:18 AM Thread Starter
Plugs were brand new and are now black.
Steering column issues/ foxbody SlowMoe General Mustang Tech 2 01-03-2014 01:29 PM
Foxbody w/S Trim and tall valve cover fitment issues 2stangs9190 Superchargers 3 11-14-2013 04:28 PM
For Sale 5.0 MUSTANGS & SUPER FORDS MAGAZINE BACK ISSUES Supercharged86 Miscellaneous Mustang Parts 3 12-31-2011 09:31 AM
CARFAX Please 85T-TopGT Lounge 3 05-17-2011 06:07 AM
Anyone run a carfax for me? SKOTHALE Lounge 6 12-23-2010 03:13 PM
