Vortech 12:1 FMU showing 10:1 - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By pkstang
post #1 of 11 Old 11-15-2017, 11:07 AM Thread Starter
I have a 91 Mustang 5.0 with a Kenne Bell. I purchased the 4FG238-068 FMU and was told it comes standard with 12:1. At WOT I?m showing 10:1 with AEM wideband. The kit came with another disc which I havent got around to trying.
I put around 25 miles on the car and checked all the plugs which look fine. Im not sure what pumps in the car but I believe its stock. The injectors are 19lb. Shouldnt I be showing 12:1 consistently at WOT?
TurboCoupe1 is offline
post #2 of 11 Old 11-15-2017, 12:31 PM
Paulie's Avatar
The ratio on a FMU refers to the amount it raises fuel pressure per pound of boost. It does NOT mean an air/fuel ratio. On a 12:1 FMU it will raise fuel pressure approximately 12lbs for each pound of boost.
1990 LX, HCI, S-trim
Paulie is offline
post #3 of 11 Old 11-15-2017, 01:34 PM Thread Starter
Okay. I?m at 5lbs am I where I should be then? If I upped to 7lbs would it be safe to run on an FMU until tune?
post #4 of 11 Old 11-15-2017, 01:35 PM
pkstang's Avatar
Trader Feedback: (161)
FMUs... i haven't heard that term since the 90s
1quick95 likes this.
pkstang is offline
post #5 of 11 Old 11-15-2017, 07:43 PM
1quick95's Avatar
Honestly,you need to get rid of that FMU and get bigger injectors and a tune.However,10:1 is rich you should be around 11:1-11.5:1 . Also make sure your timing is correct.
Tony
New project : Dads 91 LX 351W rebuild
1quick95 is offline
post #6 of 11 Old 11-18-2017, 09:09 PM Thread Starter
I plan to. This is a weekender (if that). All in time. Just wanted it safe to drive in the meantime.
post #7 of 11 Old 11-19-2017, 09:14 AM
AtomicCoupe's Avatar
This is great advice. Best thing I did
Stock block 306, V1 T-trim, AFM B-451 cam, TFS Twisted Wedge, Holley Systemax, A1000, Snow Meth, TKO 600, Team Z, Strange, MM, Lakewood and Moser helps me go forward fast.
AtomicCoupe is offline
post #8 of 11 Old 11-19-2017, 09:15 AM
This
post #9 of 11 Old 01-13-2018, 11:59 AM
94KB5O's Avatar
Have fun tuning it... I am having nightmares as we speak... I have 30# injectors and a few other things and I can't even get the idle in... blower cars are a different breed
94KB5O is offline
post #10 of 11 Old 01-13-2018, 12:00 PM
94KB5O's Avatar
A9L may be easier I hope for your sake... let us know
94KB5O is offline
post #11 of 11 Old 01-14-2018, 07:00 PM Thread Starter
Iím having a hard time right now.
For Sale VORTECH SUPER FMU ticketman2u Power Adders 2 02-16-2013 12:14 AM
Vortech FMU install HELP lephelps78 Superchargers 7 11-13-2012 01:12 PM
For Sale Vortech FMU BoostedOne Power Adders 1 10-31-2012 05:24 PM
For Sale Pro-M 92MM Meter and Vortech FMU for 42lb/hr Disgustang Fuel System & Related 24 03-31-2012 12:19 PM
12:1 FMU. What color is the disk? Chris 5.0/5.8 Engine Tech 4 01-08-2002 05:50 PM
