Anyone have a good tune for turbo 351w ?? - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By turboLXstang
post #1 of 6 Old 08-05-2017, 10:36 PM Thread Starter
I have a stock rotating assembly roller Windsor I have a mspnp2 I thought about running in it I have a on3 70mm at the moment cam specs 586/582 240/240 at 116 rhs 215cc heads 60 lb inj want around 15 psi on 93 octane any one have a good tune !? Thanks
projectx is offline
post #2 of 6 Old 08-08-2017, 12:33 PM Thread Starter
Anyone have any help thanks guys
projectx is offline
post #3 of 6 Old 08-08-2017, 02:34 PM
Trader Feedback: (22)
Not the help you are probably looking for but if you don't know how to tune yourself, you may want to consider looking into the Pro-M EFI, its plug and play and will never require you to count on someone else to tune your car for you, food for thought.
bsfguy likes this.
turboLXstang is offline
post #4 of 6 Old 08-08-2017, 03:01 PM
Lol @hoopty5.0; may have one for a "similar? combo. I can help you with an AFR table and Ignition table but I wouldn't have a decent fuel map. That will likely require you to go out and do some tuning. Since every car/setup/calibration is different, it'll be nearly impossible for somebody to send you something that is dead on. IF you need remote tuning, there are a number of guys who can do that for you. Join the MSExtra forums as well.
5.0thunder is offline
post #5 of 6 Old 08-08-2017, 03:06 PM
Also, if you get the car running, start datalogging everything. Cold idle, warm idle, cruise, etc. and we can open your datalogs and help you more. Don't romp on the throttle until we've verified you have a safe ignition and fuel table. recipe for disaster. Everybody has to start somewhere. I imagine you actually want to learn to tune? If not, you can always take it to a tuner and just get it done quick.
post #6 of 6 Old 08-09-2017, 01:05 AM Thread Starter
Awesome guys thanks for the help and feed back I will def be in touch for some pointers yes I def love to learn how to tune on point for sure !
projectx is offline
For Sale Good used eagle 351w H-Beams $175 + shipping 302blue Windsor Engine Parts 10 08-11-2017 12:17 PM
Good 351w block? HBWaterfowler 5.0/5.8 Engine Tech 0 04-14-2011 05:54 PM
going retro.. -tang Lounge 51 12-16-2010 01:47 PM
351W crate engine. good deal? PowerStrokeGT 5.0/5.8 Engine Tech 2 11-30-2001 05:01 PM
Up to how much HP are stock 351W rods good for? adam699 5.0/5.8 Engine Tech 3 11-27-2001 05:09 PM
