over revved - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-19-2017, 01:39 PM Thread Starter
over revved
Earlier in July I posted that I over revved the engine because the gas pedal got stuck under the floor mat. After going over all the info re: unable to start I exhausted all I was able to. Just had it towed (1993 mustang gt) to my mechanic and he said the computer was fried. Just FYI.
bob93gt is offline
post #2 of 5 Old 07-19-2017, 01:46 PM
How would over revving your motor fry your computer? If it was me...I would take it to a different mechanic for another opinion.
IQRaceworks is offline
post #3 of 5 Old 07-19-2017, 02:27 PM
If you overrevved it and your car doesn't start the module on your distributor probably went make sure you get the stock Original one for automatic or 5sp
Darrenstang is offline
post #4 of 5 Old 07-21-2017, 04:41 PM Thread Starter
It's official, it was the computer. Mechanic installed a used one and it runs fine. I just can't believe that little 302 could handle that much rpm!
bob93gt is offline
post #5 of 5 Old 07-22-2017, 08:19 PM
It's not the 302's fault, idk why the computer went south
5.0thunder is offline
over revved bob93gt 5.0/5.8 Engine Tech 7 07-07-2017 08:56 AM
Over revved, cylinder 5 misfire help :( zachyd23 GT & SOHC 23 05-25-2014 11:52 AM
Car shutting off after it is revved comn4u GT & SOHC 0 12-15-2012 10:57 PM
Missed 3rd gear, over revved 302 Silverpony91 5.0/5.8 Engine Tech 17 05-31-2011 11:28 PM
Belt squeeling under WOT, and when revved Dan 5.0/5.8 Engine Tech 3 12-17-2001 10:14 PM
