help with pinging - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-28-2017, 09:49 AM Thread Starter
help with pinging
ok im new to the 4.6 my 98 gt has started to ping when i load the motor i.e. cruising along and jump on it and I dont know if these have knock sensors or what else would cause this, I tried 93 oct that didnt help, I havnt done any changes to make this start, also my speedo only works when it wants to, my O/D light starts fllashing I repplaced the speed sensor on the rear of the tranny and it didnt fix the problem could the other sensor be the problem
B98gt is offline
post #2 of 3 Old 05-28-2017, 11:29 PM
Trader Feedback: (23)
You will need to pull codes on the car before anyone can help you. First guess, I would say your fuel filter hasn't been replaced in a gazillion miles, your speedo is going out, and some solenoid inside your trans is causing the flashing light.
TrimDrip is offline
post #3 of 3 Old 07-12-2018, 07:50 PM
Hi.it sounds like the speed sensor for the computer isn't working. This will confuse the computer and the OD light will flash and the shift points will change and it will do crazy things like lock up too soon causing the motor to ping.
Chris9139 is offline
What does pinging sound like? VTEC-God 5.0/5.8 Engine Tech 10 05-20-2015 02:36 AM
1988 LX Mustang - Cant have timing over 10* without pinging sluggish88 5.0/5.8 Engine Tech 25 08-17-2013 04:13 PM
Pinging even when cold, from a stop. I want it gone :( 65Wimbledon 94/95 Tech 89 10-01-2011 11:15 PM
What is pinging!!!!!!!!! 01BlkGT GT & SOHC 2 12-01-2001 02:41 AM
Pinging when decellerating? Pedronius 5.0/5.8 Engine Tech 0 11-27-2001 06:05 PM
