Good A/F table - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-20-2017, 02:32 PM Thread Starter
Trader Feedback: (18)
Good A/F table
Can anybody offer up a good N/A air fuel table? I have the auto tune and a decent AF table but I think it could be better.
'93 coupe 396, victor jr's, Trick Flow, comp solid, msd Harland Sharp, tremec, NX, always under the knife.
8.90ís on a stock block?????
dball is offline
post #2 of 6 Old 05-22-2017, 08:37 AM
What ECU is this? I'm assuming Megasquirt? If so, the base map is probably a pretty good AFR table. Best AFR's are typically figured out on the dyno where you can measure the effects of changes.
5.0thunder is offline
post #3 of 6 Old 05-22-2017, 07:10 PM Thread Starter
I thought I posted in the Megasquirt section. Lol. Not sure how I messed that up.
I'm trying to get the car up and running well before hitting the dyno. I tried changing the table some to fix a problem that I was having but I may try going back.
dball is offline
post #4 of 6 Old 05-22-2017, 09:42 PM
You may have other issues like poor fueling, EGO correction throwing things off, Acceleration enrichments, warmup enrichments. May help to post datalogs or the tune file on a google drive and share it here so we can view. Or post on MSExtra where you can directly upload.
post #5 of 6 Old 05-26-2017, 10:36 AM
Different engines run differently. Basically you need to figure out what areas are idle, cruise, moderate acceleration, heavy acceleration, and deceleration.
Your car might idle at 40kpa, where mine might idle at 60kpa. Same thing with cruising. So I can't just hand you a "good N/A map" because it's not that generic.
Once you've figured out those regions, then it's pretty standard what a typical AFR would be for each of those areas, but you have some wiggle room. Idle can be stoich or a little richer, cruise can be stoich or a little leaner. A little rich for moderate acceleration. Proper rich for heavy acceleration. Lean for deceleration unless you like popping and shooting flames.
Megasquirt
seijirou is offline
post #6 of 6 Old 05-30-2017, 09:53 PM Thread Starter
I completely understand.
dball is offline
Blown head gaskets symptoms but gaskets are good? Hypnotic818 94/95 Tech 4 09-15-2016 01:45 AM
holley dominater efi or pro m efi svoteam Engine Management Systems 120 07-25-2016 05:44 PM
Holley Metering blocks. Anyone messed with emulsion holes to improve A/F ratio? bolt-on-bandito General Mustang Tech 45 07-21-2016 03:48 PM
PLEASE HELP, 03 gt, fans wont come on even with ac on, CCRM good, fan good, fuses good danknugs420 Electrical & Wiring 1 05-12-2016 02:02 PM
For Sale Heads,rockers,intakes,pistons,camshafts and more nasty 91 Windsor Engine Parts 28 12-17-2011 02:15 PM
