I need some help/advice PLEASE! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 04-12-2017, 06:19 PM Thread Starter
Question I need some help/advice PLEASE!
My car is a 93 LX that is totally stock with the exception of a Cobra upper and lower and a BBK 65mm throttle body. It is a A3M EEC from the factory.
I purchased a X3Z Cobra EEC wiht the 24 # injectors. My question is this.. Which Mass Air meter do I need and where is the best place to source the meter?
Thank you for your time to reply.
2017 GT350 Triple black stripe delete STOCK
2004 Cobra VertTriple Black, STOCK
65 Fastback A code. Factory A/C car w disc brakes 289 C code
93 Reef Blue coupe...pretty much stock. For now... PARTS ARE ROLLING IN!
ulev1st is offline
post #2 of 2 Old 04-13-2017, 12:19 AM
With the Cobra ECU you just use a stock maf. The calibration is already done in the ECU for those injectors.
seijirou is offline
Need help/advice Holley metering block numbers dstolarc 5.0/5.8 Engine Tech 3 02-07-2015 03:17 PM
Need some help/advice.... Harley0227 94/95 Tech 1 12-17-2014 12:12 PM
2009 GT500 clutch gone...need some help/advice rel3rd GT-500 (2007-Present) 0 08-21-2014 09:11 AM
Some help/advice MS 2 3.0 Stangu2fast MegaSquirt DIYAutotune Systems 7 09-26-2013 09:18 AM
HELP/ADVICE!! with clutch selection with flywheel Leftyroc1 5.0/5.8 Engine Tech 3 01-06-2012 05:31 PM
