cleaning the IAC - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 01-08-2017, 04:50 PM Thread Starter
cleaning the IAC
I have a 2001 ford mustang GT which is supercharged and I bought a can of throttle body and intake cleaner. I noticed on the can that it said do not use on supercharged vehicles??? What can I use? Do I need to return this product?
nohea1 is offline
post #2 of 3 Old 01-09-2017, 12:27 PM
Ssp 363's Avatar
Take the iac off and clean it real good.check and see you can probably use brake parts cleaner.
Ssp 363 is offline
post #3 of 3 Old 01-09-2017, 09:29 PM
indy2000's Avatar
cleaning the IAC, usually has no effect.
If it is sticking, cleaning it rarely unsticks it.
If it is not sticking, and you have excessive buildup, you may want to find out why.
indy2000 is offline
89 Mustang GT just cranks and won't turn over after cleaning iac. rldfixup 5.0/5.8 Engine Tech 22 12-21-2012 11:29 PM
Cleaning IAC Valve and throttle body Mercedez L. 5.0/5.8 Engine Tech 6 10-14-2012 12:53 AM
Cleaning your IAC dipdonu 94/95 Tech 6 02-28-2012 11:48 PM
Idle Air Control (IAC) toddturbo General Mustang Tech 15 07-11-2011 11:56 PM
IAC, do they go out? ever? 95GT50 5.0/5.8 Engine Tech 2 01-12-2002 06:59 PM
