throttle body vs tps vs iac vs SCT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 09-19-2016, 02:30 PM Thread Starter
Mass-air foxbody question;
Would an SCT tune have control over the IAC function? You can do the procedure to set t.b. position, check tps voltage, and connect iac, but in the end can an SCT custom tune override whatever factory setting would normally step in and make factory fine tuning adjustments?
COP TZR is offline
post #2 of 5 Old 09-19-2016, 04:29 PM
SR351's Avatar
yes, the tuner would have access to modify the IAC control duty cycle. He would leave the learning adaptive on and tune the ISC scalers, dashpot, and transfer table to control idle.
94 yellow gt 704whp 753ftlbs @16lbs: E85, F4TE 351w, probe pistons, Z304DA heads, anderson b451 cam, trickflow R intake, Precision 78mm turbo, ID 1050's, tko500, Mcleod extreme clutch, 3.31's, quarterhorse/binary editor.
SR351 is offline
post #3 of 5 Old 09-20-2016, 08:35 AM Thread Starter
Second part of this question would be then, is an idle reset procedure useless without having control over the tuners settings? If you move the t.b. setscrew or the tps/voltage, the tuner settings are now invalid?
Next question would be is the ignition and injector settings also controlling some idle or low rpm control which may be factor here.
Getting this feeling that one minor adjustment to t.b. or change to tps alignment can cause a whole mess to neutral idle and rpm decel control up to low rpm drivability, pretty much fawk everything.
Not to get too sidetracked but if base timing was 9deg and reset to 10deg, does the SCT tune input total timing or a factor/adjustment add-on through the RPM?
COP TZR is offline
post #4 of 5 Old 10-17-2016, 08:29 PM
indy2000's Avatar
moving the TPS voltage has no affect, it zeros RATCH.
TB position, is airflow dependent, you need to tell the ECM how much it flows at closed throttle, that is how idle speed and IAC function in concert.
You are not going to change the duty cycle, you are going to change the amount of air, the IAC transfer will dictate, the duty cycle, you do not want to touch the IAC transfer.
Remember,
air entering past MAf=to TB air + IAC air.
750 rpm idle=a certain amount of air in the Maf transfer.
you want 750 rpm at some idle state
that maf voltage = air=TB air,,,,,,,then the IAC adds or takes air away so the MAF = 750 rpm air/voltage measured.
So you see its key to have the actual TB air to be accurate.
Ie within the ISCKAM limits.
indy2000 is online now
post #5 of 5 Old 10-18-2016, 04:29 AM Thread Starter
Thanks for the info and explanation. Spoke to a another tuner and basically said the same thing.
COP TZR is offline
Want To Buy throttle body and IAC pigtail for 02 Gt. 1redjet Electronics and Entertainment 1 05-06-2015 08:21 PM
Is tuning really not necessary for a bolt on car? 4rd Tough 94/95 Tech 67 01-27-2014 10:46 PM
DIY: Porting & Polishing a Throttle Body (Video Tutorial) ProStreetDriver General Mustang Tech 0 10-23-2013 04:04 PM
For Sale 1996-2004 FORD MUSTANG GT 4.6L 75MM THROTTLE BODY BRAND NEW! 327stkr Windsor Engine Parts 0 04-09-2011 02:38 PM
For Sale bbk 70mm throttle body and spacer w/ tps redneckmo Windsor Engine Parts 0 11-15-2010 02:24 PM
