Megasquirt turbo 351 - Ford Mustang Forums : Corral.net Mustang Forum
 1Likes
  • 1 Post By Assassin
post #1 of 12 Old 09-10-2016, 09:21 PM Thread Starter
93Svt331's Avatar
Trader Feedback: (38)
Using it on a 358,t56 turbo mustang. Here are my numbers for fuel and timing. Im looking for feedback on any numbers that look off or areas that need work.
I should be shooting for 11.2-11.5 afr under boost correct?
93Svt331 is offline
post #2 of 12 Old 09-14-2016, 03:46 PM
Yes, 11.5 is a safe AFR to target.
I assume you're not running very much boost at all if your load % only goes up to 130kPa? That's only about 4psi. If you're running more than that, I'd suggest bumping up your load column so it more accurately reflects what it will see. Around 170kPa (load %) would be about 10psi for example, depending on your altitude.
FYI, the ECU will use whatever value is in the top row of the table if you exceed that load value so you don't have to worry about it shutting down or something if you exceed the table values.
93Svt331 likes this.
Stinger-Performance.com - Plug & Play PiMPxs Standalone ECM's for 83-95 Fords
06 GT - 67mm Turbo | 85 SVO - 63mm Turbo | 86 SVO
Assassin is offline
post #3 of 12 Old 09-14-2016, 04:36 PM
Badboss351's Avatar
Do you have the upgrade with autotune? It is so worth the money, as long as you have a good calibrated wideband
XSRcylinderheads built nitrous 445".......5.32 @ 136 w/1.30 60ft (best 60 to date is 1.252)
Badboss351 is offline
post #4 of 12 Old 09-19-2016, 11:30 PM Thread Starter
93Svt331's Avatar
Crap. Just noticed I loaded the wrong pictures. I'll get updated ones tomorrow. I'm running about 10lbs now. I'm having trouble syncing my wideband with megasquirt. Does the wideband need to have the same power/ground as ms?
93Svt331 is offline
post #5 of 12 Old 09-20-2016, 08:10 AM
Bluecoupe22's Avatar
Trader Feedback: (15)
They told me that the wideband needed to be grounded to the same ground as megasquirt is , some ppl suggest grounding to battery , my experience grounding with megasquirt worked !
Bluecoupe22 is offline
post #6 of 12 Old 09-20-2016, 10:35 AM Thread Starter
93Svt331's Avatar
so same ground off frame?(computer harness in the passenger kick panel?) and also into the o2 of the main harness, correct?
thanks for your help!
and what color blue is your mustang? any pictures of it?
90 lx, 408w, T56, 88mm
93Svt331 is offline
post #7 of 12 Old 09-20-2016, 11:37 AM
The pick panel is just the case ground. It's best to ground both the ECU and wideband to the battery negative terminal if possible, with the engine block being a second best choice. Good grounds will improve the reading accuracy a lot - Ford went with a chassis ground to save some assembly time, but in my experience, a good chassis ground is usually bad, and a bad chassis ground is horrible.
Matt Cramer
Matt Cramer is offline
post #8 of 12 Old 09-20-2016, 12:57 PM
w
Here is a pic of my car
post #9 of 12 Old 09-20-2016, 10:22 PM Thread Starter
93Svt331's Avatar
Finally have the MS and LC2 paired! Will update the fuel tables tomorrow when its light out. Thanks guys
93Svt331 is offline
post #10 of 12 Old 10-16-2016, 02:45 PM Thread Starter
93Svt331's Avatar
Here are the tables and last data log.
Seeing about 9-10 psi
Couple concerns:
1. 1st holds boost 5-6 but 2-4 will loose boost seems like the gate opens. Does anyone know why this is happening?
2. When I let off the afr runs lean 22.(car is coasting)
Any tips on fixing the fuel and timing tables? Thanks guys
93Svt331 is offline
post #11 of 12 Old 10-19-2016, 05:20 PM Thread Starter
93Svt331's Avatar
update: fixed the wastegate issue now on to tweeking the tables.
93Svt331 is offline
post #12 of 12 Old 11-26-2016, 08:47 PM
The AFR is supposed to go lean when coasting. The factory ECU does this as well. It's known as over-run fuel cut or decel fuel cut. It shuts off the injectors when coasting. This saves fuel, eliminates decel backfiring, and makes it smoother on decel.
Fix the fuel table by either manually tuning it, or using VE Live (auto tune) to let the computer adjust it. Just make sure your AFR table is set to the AFR's you want it to run under varying conditions as this is what it will use to know what AFR to tune it to at idle, cruise, WOT, etc.
Timing can really only be tuned on a dyno, or on a track IF you have a really consistent car and know how to use the results from each pass to adjust timing. Short of that, all you can do is get it in the ballpark.
Assassin is offline
351 Turbo ??s Rock777 5.0/5.8 Engine Tech 3 05-18-2015 04:51 PM
Bench building 351 turbo 1984 jws4621 Turbochargers 16 01-06-2015 02:36 PM
For Sale 85 MUSTANG 351 TURBO 10.20 139 on et streets strypes1 Mustangs For Sale/Wanted, 1979-1986 5 11-20-2014 03:25 AM
How much power??? 351...67mm turbo... 03SonicBlueSVT 5.0/5.8 Engine Tech 13 08-01-2013 02:25 AM
I need your help with Ford Modular ¼ mile ET Quick list all time mobeydick Drag Racing 27 04-17-2013 02:53 PM
