Triggering 2nd fuel pump Pro-m efi - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 08-03-2016, 11:14 PM Thread Starter
So, I have a dual external fuel pump setup. I want to hook one pump up to a separate relay and trigger it via one of the programmable outputs when i'm above a certain load. I think I have it figured out on how to trigger on/off the pump but, i'm not sure what the difference between "active high" and "active low" is. Can someone explain this? Also, i'm thinking that I need to connect the output wire to the 12v switched input on the relay. Thoughts?
New Combo: 95 GT Conv., Magnum T-76 turbo, Intercooled, PDP 1-5/8" Headers w/hotside components, 60# Injectors w/Pro-M MAF
70mm BBK TB, RHS 200 64cc heads w/1.6 rr's
RPM2 Intake, Custom Hyd. cam
1FUN50GT is offline
post #2 of 3 Old 08-04-2016, 09:57 AM
Seasoned User
Trader Feedback: (97)
That's a good question. Just throwing this out there I know MDRacing makes a Fuel Pump Module that turns a second pump on when needed with MAF signal/some type of load table. Here's a link shoot him a email very nice guy to deal with
Fuel Pump
Animal is offline
post #3 of 3 Old 08-04-2016, 10:17 AM
The programmable outputs control the ground side of the circuit.
"Active High" means that the component will be active when the circuit is not grounded (open). This setting is rarely used.
"Active Low" means that the component is activated when the circuit is grounded. This is the setting you want.
Pro-M Racing is offline
For Sale Brand new Aeromotive Pro Series Fuel pump... ChadR Fuel System & Related 1 01-12-2013 05:00 PM
For Sale PAS -340LPH High Pressure In-tank Fuel Pump PowerAdder Solutions Fuel System & Related 66 10-09-2012 09:53 PM
For Sale 1300HP SX fuel pump w/ filters EFI (or carb) not fast Fuel System & Related 12 01-23-2011 10:03 PM
