Anyone running Contour fans with a PWM controller - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-28-2016, 12:14 PM Thread Starter
TxFireman1972's Avatar
Trader Feedback: (87)
I tried asking in the General Tech section but wanted to ask in here too.
In the process of finishing up my 93 Coupe. Been installing a Holley HP EFI system along with a Vortech V2-Si. Decided I'm going to go ahead and install a set of contour dual fans. I'm going to control them with the Holley using the PWM output.
I'm curious if anyone is running the Contour dual fans with a PWM controller. I picked up a Corvette C6 fan controller, which is what a lot of guys on the pro-touring type websites are using. Most of them use the C6 fan too, which I actually have one of those too. The drawback is that it does not use a shroud, so I would need to fabricate one.
I've used the Contour fans in the past using a DCControl fan controller with no problems.
Like I said, just really wanting to see if anyone is running Contour fans with a PWM style controller. If so how do you have your fans wired?
One day the same people that doubt your dream will tell people how they met you!
TxFireman1972 is offline
post #2 of 4 Old 08-10-2016, 07:34 AM
DLW
DLW's Avatar
Correct me if I am wrong, but I thought the DCC unit was PWM relay.
DLW is offline
post #3 of 4 Old 08-31-2016, 10:17 PM
Stew_Magoo's Avatar
Nobody?
1993 Mustang LX Coupe H/C/I 306/T5/IRS
1997 Lincoln Mark VIII
Stew_Magoo is offline
post #4 of 4 Old 08-31-2016, 10:20 PM Thread Starter
I ended up using a C6 Corvette fan mounted in my factory Mustang shroud, along with a C6 PWM fan controller
Anyone running Contour fans with a PWM controller? TxFireman1972 General Mustang Tech 0 07-28-2016 02:12 AM
Contour fans fasterthangas Electrical & Wiring 5 06-27-2016 08:26 PM
differences in oem vs dorman contour fans sprayed347 General Mustang Tech 3 07-06-2015 04:05 PM
Dual contour fans ? sleeping stallion General Mustang Tech 14 07-10-2013 02:10 PM
Anyone running a Fuelab electrinic fuel pressure regulator/pump controller ? rkloehn Superchargers 6 06-14-2012 10:33 AM
