MAF codes. - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-26-2016, 01:21 PM Thread Starter
Trader Feedback: (21)
MAF codes.
I keep getting the code #26Mass Air Flow Sensor was greater than 0.7 volts with engine off (O), MAF sensor was not between 0.2 and 1.5 volts with engine running (R). What if any is the correct procedure to test my MAF trouble.
boostup89 is offline
post #2 of 2 Old 07-26-2016, 04:01 PM Thread Starter
I believe I found my issue. But would still be interested in knowing if there is a way to test a maf.
Need 92 5.0 MAF circuit help MFE EEC Tech 0 05-31-2013 11:47 PM
MAF Tuning Correctly, TwEECer R/T & Quarterhorse Systems PowerAdder Solutions Engine Management Systems 0 08-28-2011 08:51 PM
codes 172 & 176, not MAF, really need help! Stang_Shane 94/95 Tech 0 08-28-2011 08:13 PM
MAF gone bad?? ScottsGT 94/95 Tech 2 05-21-2011 06:10 PM
