Stock Intake Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 07-24-2016, 10:06 PM Thread Starter
Hey Everyone, Possibly a stupid question but... With all of the manifold options available for fuel injection from aluminum single planes to sheet metal type why do most seem to stick with the stock set up? Are there specific advantages?
Thanks in advance.
Stew4706 is offline
post #2 of 4 Old 07-25-2016, 11:21 AM
Yeah, it's cheaper. It's a good intake for low end torque, but an aftermarket intake manifold can help at high RPM.
Matt Cramer
Matt Cramer is offline
post #3 of 4 Old 07-25-2016, 11:22 PM Thread Starter
Thanks Matt, that is what I suspected. Are folks generally using the factory PCM for stock or mild builds as well? I have read through the different threads and it appears that most of the bigger builds are going with different controllers.
Dave
Stew4706 is offline
post #4 of 4 Old 07-26-2016, 08:06 AM
The stock mass air computer can handle a few mild modifications, although getting a tune is always preferred over running the stock tune with aftermarket parts. There comes a point when your build becomes too extreme for a stock ecu to compensate for, even with chip tuning. Aftermarket ecu's give you control over more variables/parameters that allow you to better tune your specific combination.
5.0thunder is offline
5.8 Install Boosted5.8 5.0/5.8 Engine Tech 19 06-28-2015 04:48 PM
advice on best mod to get next ! Nally427 94/95 Tech 27 04-13-2015 10:55 AM
Help Wanted! PLEASE Read. (BLOWER CAMS) MARK 302 Superchargers 53 02-24-2012 09:51 PM
Edelbrock intake w/ nitrous question stumbaugh GT & SOHC 2 12-16-2010 12:01 PM
