CEL code #26 - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 07-03-2016, 08:33 AM Thread Starter
Trader Feedback: (21)
CEL code #26
Getting closer on my tune and check engine light is on. Getting #26 - Mass Air Flow Sensor was greater than 0.7 volts with engine off (O), MAF sensor was not between 0.2 and 1.5 volts with engine running (R). Do I change the "MAF voltage minimum" to a lesser value than what is in my maf curve table? Or do I have something else going on. I would also like to add some fuel durring decel, should I decrease the low slope? It gets lean enough to make some coughing. I'm using Tweecer with an a9l.
boostup89 is offline
post #2 of 2 Old 07-12-2016, 12:52 AM
indy2000's Avatar
what is your logged mafv, at lowest idle?
indy2000 is offline
CEL & Code 15 (on demand) w\ SCT Chip post HCI FOXVERT91 5.0/5.8 Engine Tech 6 01-31-2015 10:30 PM
CEL code 41 and 91 Mstng93SSP General Mustang Tech 6 04-15-2014 07:19 PM
Ford SVO Extender Causing CEL Code 61 93 Mustang FivePTSlow Engine Management Systems 1 05-29-2013 12:55 AM
dual fpdms added..fuel issue with CEL code 1233? blk003GT GT & SOHC 7 05-15-2011 08:55 AM
Who has access to Oasis reports? straightliner1 Lounge 4 02-28-2011 01:19 PM
