Tune help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 9 Old 06-08-2016, 10:35 PM Thread Starter
finchinzo's Avatar
Tune help
So took freshly built coupe in for chip tune on stock ecu. Was a little electrical issue, they fixed that them found out stock computer was fried. So the chip itself costs $250 and a new factory ecu is $250... I've considered the megasquirt plug and play and let them tune it at the speed shop.. There not a big price difference after buying new ecu and chip. Any recommendations? I just want to make safe power. Car will go to track occasionally but mainly weekend cruiser with cold AC. Car was originally built for YSI but just has s trim now. What's the best route to take?
342 boss block dominator stroker kit
Trick flow heads with stage 2 fox lake Cnc port
Trick flow box r
65# precision injectors
5 speed
finchinzo is offline
post #2 of 9 Old 06-09-2016, 04:01 AM
wytwolf's Avatar
The Megasquirt will give you much more room to grow without having to get your chip redone every time. The support community for tuning is great with quite a few members here as well as other sites. MSefi is a good one. You have potential to make big power, which IS doable on an A9 computer, I've seen 850+, but why not open up your potential for more. I'm currently running a PIMP system which is MS based. Sadly, I haven't had the time to put into the tune as I'm having other issues now. I love the ability to manipulate everything. I have more I/O's than I need, and learning about tuning is amazing. Hoping to get the gremlins worked out and get this thing running strong. Hopefully my Dart motor will be ready for transplant soon!
wytwolf is offline
post #3 of 9 Old 06-09-2016, 08:18 AM Thread Starter
finchinzo's Avatar
Thanks for your input, I appreciate it. I'm certainly frustrated I'm ready to drive this car already. Since I need another a9l, and have to buy a chip, the plug and play is just 450 more. Seems like it may be the smart route.
post #4 of 9 Old 06-09-2016, 08:36 AM
Are you taking the car to Triangle or what? I don't know many houston shops that tune megasquirt cars.
5.0thunder is offline
post #5 of 9 Old 06-09-2016, 11:25 AM Thread Starter
finchinzo's Avatar
yes car is at triangle now
post #6 of 9 Old 06-09-2016, 12:39 PM
Cool, Look around for a used unit and maybe you can score one for 5-600. update the thread after they tune it and let us know how it drives and what the tune looks like. also, you can usually find factory ECU's for 100-150 bucks around houston and corral. that'd make the factory ecu option a bit cheaper for you.
post #7 of 9 Old 06-09-2016, 06:44 PM Thread Starter
finchinzo's Avatar
Thanks again for input, will do. I found used ones for $150, but didn't know if it would be better to do the freshly reman ecu for $250? Also I'm certainly in the dark on the tuning stuff. I did find a new used mega plug and play 2 for about $700. So that even gets cheaper. I don't care that much about saving a few dollars, really just want the smarter option whatever that is.
post #8 of 9 Old 06-17-2016, 10:47 AM Thread Starter
finchinzo's Avatar
Finally got the car back, it runs very strong at wide open throttle. Runs horrible from the 1700-3000 rpm range... It is clearly loading up on fuel at this time and the car just bogs down.. Wishing I would've done the mega squirt plus/play 2 now.... Hopefully they get it doing now. Been a lot of trouble getting this thing tuned.
post #9 of 9 Old 06-20-2016, 09:43 AM
I thought you were gonna pick up that PNP G2 setup!
Rdrcrís 2013 Mustang GT Upgrades and Reviews Thread. Rdrcr S-197 Mustang GT (2011-2014) 62 12-11-2014 12:36 PM
For Sale 5.0L/Vortech SCT chip, tune, 85mm MAF TxFireman1972 Power Adders 0 09-11-2014 04:42 PM
Tune -Wraith- MegaSquirt DIYAutotune Systems 8 07-30-2014 02:07 AM
AM/BAMA tune oddity? CHRGDPNYBOY S-197 Mustang (2005-2010) 12 08-27-2011 02:24 PM
Custom Tunes: BBR or BAMA? CHRGDPNYBOY S-197 Mustang (2005-2010) 19 07-22-2011 05:32 PM
