multiple faulty sensors? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-01-2016, 11:22 PM Thread Starter
Trader Feedback: (21)
So working on tunning my car, and having some issues. My ect, act, tps, sensors as well as spark are literally not doing anything during datalogging. The tps is staying at 1.29 and never changes when throttle is applied. ????? Bad ECM?
boostup89 is online now
post #2 of 5 Old 06-02-2016, 09:45 AM
This could also be a fault in the wiring, particularly sensor ground wires.
Matt Cramer
Matt Cramer is offline
post #3 of 5 Old 06-02-2016, 10:59 AM Thread Starter
I have a known good a9l computer to swap into the car tonight. If this sensors start working I know it's a bad ECM. If they still don't work I have a wiring/sensor ground problem. Is this a fair statement?
post #4 of 5 Old 06-02-2016, 07:40 PM
Pull the computer and look to see if you have a burned SIG RTN trace.
Very common when people play around with tranmission and harness swaps...you can even accidentally burn it out while trying to check codes if you aren't careful.
bsfguy is offline
post #5 of 5 Old 06-02-2016, 11:07 PM Thread Starter
Well turns out the old A9l is indeed junk. No trace burns or even any signs of damage, but when datalogging with it there are obvious sensors not reading. Changed out for a known good unit, all sensors working properly.
OXYGEN sensors stwarrior23 General Mustang Tech 7 03-16-2016 09:49 PM
For Sale Ford 02 sensors new in package jmcclesk Modular Engine Parts 4 08-01-2015 03:13 PM
For Sale Stock Distributors, coils, TPS sensors, TFI mods, Map Sensors, 02 sensors, inertia Sw GMundertaker Electronics and Entertainment 0 01-13-2014 04:53 PM
AEM EMS with Explorer Sensors and LS2 coils - How To Donovan AEM EMS 18 06-25-2012 05:58 AM
