WOT cutout with Holley EFI? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 05-27-2016, 06:45 PM Thread Starter
TxFireman1972's Avatar
Trader Feedback: (87)
I just got all my Holley HP EFI stuff in for my 93 Coupe. I drive my cars a lot so it definitely has AC. Of course some of the AC wiring is going away with the factory EFI harness. I want to set it up just like it was factory, but integrated in with the Holley EFI. I can use one of my outputs to send a AC signal at a set RPM. This is how I'm planning on wiring up the AC WOT cutout relay to the Holley HP using a standard SPDT relay.
This would have power (positive) coming into the relay from the AC pressure switch to the common (30), negative from the Holley EFI on WOT to one side of the coil (86), and positive from switched 12volt to the other side of the coil (85). This would give power to the normally closed (87a) under non-WOT operation which would engage the AC clutch, and would open under WOT condition which in turn would disengage the AC clutch.
Mainly just wanting to confirm my wiring and see if everyone likes it or has a better way in mind. Thanks in advance!
One day the same people that doubt your dream will tell people how they met you!
TxFireman1972 is offline
post #2 of 2 Old 05-30-2016, 12:10 AM
Paulie's Avatar
I think that should work fine. When the Holley grounds the relay coil it will cut power to the compressor clutch.
1990 LX, HCI, S-trim
Paulie is offline
Holley hp EFI unit irman393 Electronics and Entertainment 12 01-03-2016 03:08 PM
For Sale Holley EFI Fuel pump kit -NEW SBpilot Fuel System & Related 1 06-26-2015 11:47 PM
Holley HP EFI Wiring DLW Holley EFI Systems 19 02-23-2015 05:41 PM
anyone run Holley EFI HP system with nitrous? musthave302 Nitrous 0 03-30-2013 10:51 AM
For Sale Selling it ALL – SBF and SBC, EFI Intakes, TrickFlow, Edelbrock, Ford Racing, Holley Y2KR Windsor Engine Parts 15 08-28-2011 06:13 PM
