MS3-Pro instal ?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-14-2016, 07:56 PM Thread Starter
rotax's Avatar
Question MS3-Pro instal ??
On a Fox mustang, It doesn't look like they make an engine harness.
Is it just unterminated wires that you must finish the connectors? Is there a terminal and connectors kit?
Anyone installed it on a fox before? Any inputs or trick you can share?
Questions... questions..
R331 GT47
rotax is offline
post #2 of 3 Old 05-16-2016, 03:10 PM
Yes, it's currently just an unterminated harness. We don't have the Ford sensor connectors available now, but you can find most of them (with the apparent exception of the TPS connector) from your local auto parts store or a place like RockAuto.
Matt Cramer
Matt Cramer is offline
post #3 of 3 Old 05-30-2016, 07:57 PM
Please call me Mike
mr_minnis's Avatar
Trader Feedback: (46)
Like Matt said you should be able to get the pig tails from a parts store. However as long as the locking tabs aren't broken the ones from your existing harness are probably ok.
I've heard the issue about the TPS pig tail also. I don't get why there is a shortage or whatever.
You also may want a relay center of some kind, fuses, and power wire. Some folks seperate the management stuff out of the factory fuse panel for simplicity.
mr_minnis is offline
For Sale FOR SALE: Ford 8" Auburn Gear Pro Series Differential w/center section steveOfiveO Drivetrain Parts 0 07-17-2015 06:36 AM
ms3 pro or the ms3 goldbox NotNatural86 MegaSquirt DIYAutotune Systems 2 07-14-2015 10:31 AM
Want To Buy MS3 PRO NotNatural86 Electronics and Entertainment 0 07-11-2015 10:28 AM
For Sale 91 Pro Street Ranger Exten. Cab Built 306 & C4 MUST GO ASAP thunderace31 Other Fords and Trades 5 09-09-2011 09:04 AM
