Anderson Fordmotorsport PMS Tuner (4) - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-10-2016, 03:18 PM Thread Starter
BigBlock88's Avatar
I recently built a 347 NA 91 GT for my buddy and am using the PMS Tuner. I am trying to set a baseline tune to start with before I start using the tuner. Specs are as follows: 347, TrickFlow top end kit, 36lb injectors, 75mm mass air and throttle body, Lentech AOD, 3.55, 210 LPH pump, BBK fuel fails and regulator. Using the stock ECM since the tuner piggy backs it / goes between. I believe the fuel pressure should be 39psi (with no vacuum) and the timing should start at 10*. I. Just looking for guidance since I've never used this tuner before. Engine is fresh with 0 miles. Any help with startup and settings would be greatly appreciated. Motor has roughly 10.5:1 - 11:1 compression.
BigBlock88 is offline
post #2 of 3 Old 05-10-2016, 06:43 PM
Draggin90's Avatar
Trader Feedback: (29)
Leave the idle control off. Pull ~35-40% startup fuel and add +6* of timing. Your base timing and fuel pressure should be good. That should get you started up and tuning from there. There are some startup tunes here:
https://forums.corral.net/forums/pms-...base-tune.html
Draggin90 is offline
post #3 of 3 Old 05-10-2016, 08:17 PM Thread Starter
BigBlock88's Avatar
Wow- thank you very much!! That helps tremendously! You guys are great. I didn't expect such a quick response. Thanks again!
For Sale Anderson PMS 4 89-93 and LM2 jmcilvain Electronics and Entertainment 3 01-27-2016 12:22 AM
For Sale *MINT* Anderson PMS 4, ACQ datalogger, 3-bar MAP, J4j1 Cobra ecu, tunes, datalog pages & EXTRAS package! WadeScott Electronics and Entertainment 11 10-24-2015 12:03 AM
For Sale Anderson Ford Programmable Management System (PMS) with map sensor zero_chance Electronics and Entertainment 1 02-19-2012 09:10 AM
For Sale Anderson PMS with MAP sensor for Foxbody Mustang - $600 Jimmy_Rawzy Electronics and Entertainment 6 01-03-2012 11:23 PM
For Sale Anderson PMS for 1996-1998 GT, Sniper Deltaforce Tuner for Fords + misc parts HighPsi5O Electronics and Entertainment 11 11-25-2011 07:11 PM
