On3 Fox Hard starting and stall - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 02-23-2016, 10:40 PM Thread Starter
Hey Guys I just put a on3 70mm kit on my car(1989 fox) So the car starts and Runs Parked perfectly Idles Great. So here my Problem
1.starting the car in [coldstart] then start to drive the car for about 5 min and come to a Rolling stop the Car will stall out. Then I'll try to start it but it only cranks? Then I floored the gas and crank it and it starts but starts to Miss and won't rev up at all even if the pedal is Floored.
2.If I start the car [cold start] It will run forever..but when I turn the car off it won't start up unless I Floor it and after it starts I have to keep it floored so the car will stay on But has a misfire and won't rev up at all.
SJFOX89 is offline
post #2 of 2 Old 03-01-2016, 12:27 PM
Sounds like it could be a bad coolant temp sensor. If you floor the gas pedal while cranking, the ECU turns off the injectors and that's why it fires with a bad coolant temp sensor. The ECU is flooding the cylinder in hot start because of a bad sensor or broken sensor wiring.
Keith Munroe "GDDYUP2"
QTRMILE
see, Ian drives it like Satan is chasing him downtrack. If you want to run the number, you gotta put the life of your parts on the line.
GDDYUP is offline
For Sale Fox Coupe boostdcoupe Mustangs For Sale/Wanted, 1987-1993 7 12-25-2014 04:52 PM
car wants to stall after getting on it hard brando87gt 94/95 Tech 2 06-13-2014 09:36 AM
87 GT still drag starting when hot and a stall.. 87gtconvert 5.0/5.8 Engine Tech 8 09-28-2012 06:37 PM
