EZ EFI or FITECH or Stock Style?? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 02-23-2016, 05:37 PM Thread Starter
BarneysBullitt's Avatar
I am building a 72 F100 with a 351W (AFR185 with a mild cam) and 5 speed. I am trying to decide what to do on EFI.
Choice #1
I have a Ford Racing harness and ECU (foxbody style) that I had planned on using but will require dyno tuning
Choice #2
I have access to the Fast EZ EFI 2.0 multiport setup but would need to buy a distributor and all of the sensor stuff to convert from GM over to my Ford engine. Seems as if the system is designed around GM stuff. Also seems tech support is not that great.
Choice #3
FITECH throttle body setup. Very easy install and setup plus reasonable price.
I know multiport is more efficient but for a "shop truck" type setup, getting the extra tenth out of it is not important. If it was your truck and it is a budget build, what would you do?
Barry
90 LX Triple Black Vert, 306, B303, Cobra 1.7 Roller Rockers, GT40 ported iron heads, Cobra intake, shorties, 65mm TB, 73mm C&L, 24lb injectors, Cobra front brakes, Lincoln rear discs, 3.55 gear, sub frame connectors, strut tower brace, Bilsteins and coilovers, Flowmaster Thunderseries
BarneysBullitt is offline
post #2 of 3 Old 02-24-2016, 09:14 AM
Choice #1
Choice #2
Choice #3
Barry
Choice 3. least amount of modification required. Tuning the EEC comps with a chip can be very expensive and I never find that option attractive. EZ EFI is probably okay but I don't have experience with FAST systems and I feel the conversion would be more costly for no performance gain. People in your situation seem to be flocking to FI Tech systems (or other TBI setups) and end up with good results. proper running engine, basically no maintenance, and much improved reliability.
5.0thunder is offline
post #3 of 3 Old 02-25-2016, 11:28 PM Thread Starter
I am beginning to think the same thing. It's just a simple install and looks to be very reliable. Thanks for your thoughts!
Barry
Help! Removed stock EFI now window doesnt roll up 94_cobRa 94/95 Tech 8 08-07-2014 07:11 PM
COMPLETE How To Install M90 on 4.OL V6 SOHC - Mustang 05-10 moddbox Superchargers 0 05-08-2014 01:33 AM
For Sale Stock parts 04 gt auto vert gogone3 Suspension 12 04-16-2014 06:28 PM
Stock STYLE FP regulator HP limit? jonyboy107 5.0/5.8 Engine Tech 7 07-31-2011 09:53 PM
Will a super vic efi intake work on a stock computer alliedasset 5.0/5.8 Engine Tech 6 02-13-2011 09:39 AM
