91 gt issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 36 Old 02-13-2016, 05:52 PM Thread Starter
87fubar's Avatar
91 gt issue
not sure if this goes here
I picked up this 91 gt for parts car id like to hear the engine before I pull it apart
I'm not getting signal to fuel pump relay from the ecm an my code reader isn't reading the ecm is even there the fuse links look good idk were to check next
projects never are truly done you'll always end up finding something better to install /modify
87fubar is offline
post #2 of 36 Old 02-13-2016, 07:28 PM
indy2000's Avatar
what signal are you looking for?
indy2000 is online now
post #3 of 36 Old 02-13-2016, 09:06 PM Thread Starter
87fubar's Avatar
I was check to see if the ecm was grounding while cranking but I was getting nothing while cranking
if I jump the fuel pump directly at the relay plug I get 45 psi to the injectors got nothing while cranking after I got the pump to prim I don't think the injectors were spraying the Schrader valve gauge the PO had on there did move at all while cranking
87fubar is offline
post #4 of 36 Old 02-13-2016, 09:54 PM
indy2000's Avatar
will it prime in run?
for the pump to run, there must be an rpm signal on the PIP, from the ICM
it is the cam/crank signal.
is there spark?
post #5 of 36 Old 02-13-2016, 11:04 PM Thread Starter
87fubar's Avatar
ok this is what I got I have constant power then a switched power at the relay pump will not prim with key if I jump from the constant power to the fuel pump it'll prim
ive also tried swapping relays from my running car with no luck
I picked the car up for $2500 guy I got it from showed me a book 3" thick of paper work on engine an trans
port / polished edelbrock heads roller rockers x303 cam I think pistons are trw flat tops with flycut trick flow intake has bbk 75mm TB egr plate 80lbs injectors with calibrated 80mm maf
87fubar is offline
post #6 of 36 Old 02-14-2016, 12:23 AM
indy2000's Avatar
the ECM supplies the ground for the control of the relay
all you have to do is put a test from batt + to the ground, turn the key to run, does the light come on?
no? then no prime
NOW, make sure we are on the same page
the prime ONLY happens in run, NOT crank.
if you have the prime in run, but no pump in crank you go straight to the ecm input like I said.
post #7 of 36 Old 02-14-2016, 12:47 AM Thread Starter
87fubar's Avatar
I had a test light from constant power at the relay an the negative side to the signal/ground light never came on
when I turn the key to on position I can hear what sounds like a relay from pass side of the dash I hear it click on couple seconds then sound like it clicks off
kinda had the same issue with my 89 gt when I first got it but that one was PO put a fusible link hooked up to a ground instead of starting solenoid
the PO of my 91 i just got was trying to get it going has a new 190lph pump in the tank he pulled the distributor to prime the oil system but that was as fare as he got car sat for 3 or 4 yrs
i know the fuel pump only primes for 3 to 4 seconds when turned to run position
87fubar is offline
post #8 of 36 Old 02-14-2016, 10:26 AM
indy2000's Avatar
take the test light from BATTERY POSITIVE
TO the ground side of the fuel pump relay COIL, TURN THE KEY TO RUN
Does the light come on?
do the tests one step at a time like I suggest, unless you are 100% confident in what you are looking for.
post #9 of 36 Old 02-14-2016, 06:50 PM Thread Starter
87fubar's Avatar
ok did the positive on the battery an the other on the ecm ground at the relay as soon as I plugged it in the test light came on even before I turned the key it dimmed a bit while cranking but stayed on solidly is that a bad sign of wiring issue
I tried swapping the relay above the ecm same click ive been hearing
87fubar is offline
post #10 of 36 Old 02-14-2016, 07:33 PM
indy2000's Avatar
that is bad, and the pump should be running continuous, is it?
the click from the eec relay, normal
post #11 of 36 Old 02-14-2016, 07:50 PM Thread Starter
87fubar's Avatar
only time the pump will run is if I jump it at the relay plug
87fubar is offline
post #12 of 36 Old 02-14-2016, 08:05 PM
indy2000's Avatar
jump what ...............?the power or ground
you are not describing or testing properly
the relay should have power on both the line and control, key in RUN
the ECM supplies the ground to allow the power through to the pump~1second
YOU said you had a ground on the control side, RIGHT, with the test light.
therefore the pump should have come on,
you say it doesn't, you are not testing correctly or telling me correctly what you are testing.
post #13 of 36 Old 02-14-2016, 08:35 PM Thread Starter
87fubar's Avatar
there is 2 big wires an 2 small wires at the relay if I jump the 2 big wires the pump runs now when I did the positive battery to either small wire with out touching the key the light comes on
87fubar is offline
post #14 of 36 Old 02-14-2016, 11:28 PM
indy2000's Avatar
when the light comes on, that means there is a constant ground.
either the ecm is hooped, or you have a short to ground.
now go to batt negative with the test light
touch the two small wires, and turn the key to run, what does the light do?
post #15 of 36 Old 02-14-2016, 11:55 PM Thread Starter
87fubar's Avatar
ok just reread it I miss read it the first time one of the small wires gets power when ignition switch is turned
I thought I read your post as I test the 2 small wires together with the test light I tried that didn't light up at all
87fubar is offline
post #16 of 36 Old 02-15-2016, 01:01 AM
indy2000's Avatar
does the light come on when touching either small wire?
I cannot understand your answer, keep it simple, yes or no.
post #17 of 36 Old 02-15-2016, 02:10 AM Thread Starter
87fubar's Avatar
yes one of the small wires the one closest to the big wires
87fubar is offline
post #18 of 36 Old 02-15-2016, 09:29 AM
indy2000's Avatar
that concludes it,
you have a power and a ground, for both control wires
if this is true, the coil of the relay is open, you can ohm the coil or do a volt drop across the coil
remove the relay, and give a power and ground to the coil pins, you should hear a click, and the line contacts should close.
post #19 of 36 Old 02-15-2016, 10:39 AM Thread Starter
87fubar's Avatar
ive tried the relay out of my running car in this 91 wouldn't do anything
while I was at it I plugged the relay that was in the 91 in my 89 an fuel pump in my 89 ran like normal
87fubar is offline
post #20 of 36 Old 02-15-2016, 07:12 PM
indy2000's Avatar
then what you told me regarding the test, or the way you tested, was incorrect
do you want to start at the beginning?
post #21 of 36 Old 02-15-2016, 09:12 PM Thread Starter
87fubar's Avatar
id did it the way u said to test it
the ground signal wire from the ecm seams to have ground no matter what doesn't matter if I turn the key or not
the next small wire gets power when I turn the key
then the constant power bigger wire
then the other bigger wire that goes to the inertia switch
should I check what voltage I'm getting at the relay
87fubar is offline
post #22 of 36 Old 02-15-2016, 09:44 PM
indy2000's Avatar
is the inertia switch closed??
I assumed you checked that.
and you should NOT be getting a constant ground
post #23 of 36 Old 02-15-2016, 10:09 PM Thread Starter
87fubar's Avatar
ya I checked the inertia switch
87fubar is offline
post #24 of 36 Old 02-15-2016, 11:39 PM
indy2000's Avatar
you say you have power to control side of relay
and you say you have a constant ground to the control side of the relay
and you say the relay will not close to allow the pump to come on.
I am going to say it is NOT possible, as you said the relay works on another car.
So, without question, you are not doing the testing correctly
that is the only possible reason...there is no other
I think you are finding the ground, through the wrong side of the relay, the fuel pump side, as that is the ONLY constant ground, in this entire circuit.
post #25 of 36 Old 02-16-2016, 12:50 AM Thread Starter
87fubar's Avatar
all I know is I did the ecm ground thing like you said to do it an its getting constant ground my test light dimed while cranking but never blinked fluttered
but the other thing that has been bugging me is my code reader wont read anything from the ecm
when I turn the key to run I get all the normal lights on the dash the check engine light comes on for 3 to 4 seconds
87fubar is offline
post #26 of 36 Old 02-16-2016, 09:28 AM
indy2000's Avatar
I am saying is you were not on the ecm ground, but the load side of the fuel pump on the relay.
so you were trying to power the pump with your test light, that is why it went very dim.
maybe take pics of the tests you are doing.
Like I said, you cannot have what you describe, it is electrically impossible.
post #27 of 36 Old 02-16-2016, 12:11 PM Thread Starter
87fubar's Avatar
there is only 2 wires that are not getting power one big wire an one small wire
the big wire if I put positive to it the pump primes so that leaves that one small wire that I tested the way you told me to test it
so its either the ecm is putting out power to the relay or could have a short some were
I'm not here to rub ppl the wrong way I'm here to get direction so I can try getting this to run so I know if engine ok before I drop the engine into my 89
87fubar is offline
post #28 of 36 Old 02-16-2016, 06:18 PM Thread Starter
87fubar's Avatar
ok
prong 1 fuel pump control (this would be the ecm ground correct ? )
prong 2 power from eec power relay (my switched power wire )
prong 3 fuel pump output (the wire I put power to an get the pump to prime )
prong 4 ignition fused power (my constant power )
found this on (easyautodiagnostic.com) how to test green ford fuel pump relay
87fubar is offline
post #29 of 36 Old 02-16-2016, 10:27 PM
indy2000's Avatar
post a link
post #30 of 36 Old 02-16-2016, 10:53 PM Thread Starter
87fubar's Avatar
not sure if I got the pic thing here figured out should be a pic of how they number the plug/relay
idk how to post a link to website
87fubar is offline
post #31 of 36 Old 02-17-2016, 10:12 PM
ndmus88gteng's Avatar
Trader Feedback: (140)
here ya go the website you were wanting to post
link : Part 1 -Ford 4.9L, 5.0L, 5.8L Index of Articles
88 hatch 427 Dart FordStrokers,Tmoss ported SuperVic, Hi-Port 225's , Freezy custom cam, Pro-M engine management system with cnp,
Aero fuel pump wiring, alt upgraded wiring, Flex-a-Lite 52185 radiator/fan combo, T56 Magnum kit , built 8.8 rear-end 3:73 with 31 spline axles welded 03 Cobra center section.
might be ready to dyno and run it by next summer of 2017,LoL I hope!!
March 2018 new 2018 F150 super cab "Blue Lightning" 2.7 Twin turbo'd 10 speed automatic
ndmus88gteng is offline
post #32 of 36 Old 02-17-2016, 10:21 PM
indy2000's Avatar
ready?
post #33 of 36 Old 02-17-2016, 10:31 PM Thread Starter
87fubar's Avatar
do they have the right wires marked
there site doesn't say what to do if the light stay's on when key is turned off when checking ecm ground
but its raining right now so cant mess with it till it stops
87fubar is offline
post #34 of 36 Old 02-19-2016, 07:36 PM Thread Starter
87fubar's Avatar
rain is suppose to clear up tomorrow so ill be able to mess with the mustang
87fubar is offline
post #35 of 36 Old 02-23-2016, 08:37 PM Thread Starter
87fubar's Avatar
ok did some messing around with it the msd 6a box didn't seam to be working so I pulled it out hooked up the factory plug to the coil its now showing rpm while cranking
then the clutch switch died on me so it stopped cranking till I bypassed it got it to crank over but then I noticed the ecm relay wasn't clicking I bumped the ignition switch wiring with my knee an the ecm relay clicked couple times so I'm thinking the issue is in that ignition switch plug
87fubar is offline
99 GT PCM Issue rlubrich87 GT & SOHC 6 03-30-2014 05:28 PM
03 GT clutch issue 03DSG4.6 GT & SOHC 6 03-23-2014 06:50 PM
For Sale Parting out 2002 Mustang GT bmwm3 Interior Parts 12 03-03-2014 08:07 PM
99 GT Fuel pump issue Corey03_svt GT & SOHC 5 03-27-2013 02:08 PM
94 GT no start issue MUSTANGTERMINATOR 94/95 Tech 9 01-03-2011 01:30 PM
