A9L with PMS will not stay in WOT - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 02-09-2016, 01:45 PM Thread Starter
abes's Avatar
I have a A9L computer with a PMS series II. Brand new Pro-M mass air meter calibrated to 30lb injectors. Engine is a 347. The car runs great and made good power on the dyno but I am having some sort of electrical issue maybe. At WOT the car runs out great but the ECM jumps out of WOT to PrL 7 and PrL 8. It does this at about 3500 and 5000-6000. This is not right. I am not able to make any reliable tuning adjustments.
Has anybody encountered this before?
Some things I have done:
Set base idle multiple times.
Replaced TPS with OEM Ford product.
Checked all grounds.
Grounded the PMS box to the chasis.
Thanks in advance for any input.
abes is offline
post #2 of 5 Old 02-09-2016, 09:22 PM
10sec5oh's Avatar
Trader Feedback: (74)
Put your HL table settings the same as your WOT. Have you verified you are getting WOT and idle on the display after you have reset your idle?
89 LX S-trim and GT40's
10sec5oh is offline
post #3 of 5 Old 02-10-2016, 02:07 PM Thread Starter
abes's Avatar
I have verified WOT and idle after the base reset.
The problem with moving the WOT table into the HL table is that the computer runs in closed loop under high load. Timing and fuel curves change depending on sensor inputs. In WOT the computer runs in open loop which uses a predetermined timing and fuel maps according to rpm. This is my understanding of how the A9L works.
So with this issue I can not spray due to ever changing timing and fuel.
Could there be a short in my harness? Could it be related to my new Pro-M mass air meter? I have made multiple calls and email attempts to Pro-M, but have not received a response yet. I think I am getting ultra close to getting a stand alone system.
abes is offline
post #4 of 5 Old 02-10-2016, 02:38 PM
10sec5oh's Avatar
Does your PMS have stand alone? If so and that is turned on it overrides what you are trying to explain with the A9L. Contact Doug at EFI systems he makes the PMS.
EFI Systems Inc.
10sec5oh is offline
post #5 of 5 Old 02-10-2016, 03:45 PM
We received a single email message from you yesterday at 1:24 PM eastern time. I personally responded at 1:36. There are no voicemail messages.
My direct line is 508-867-6733. Although this is not a MAF problem, I am quite sure I can solve it for you. If I don't answer, you'll need to leave a message.
Pro-M Racing is offline
For Sale AFM PMS 4 for Fox and A9L red91coupe Electronics and Entertainment 8 09-25-2015 05:35 PM
PMS Series 4 Timing 187mustang PMS Tuning 6 07-13-2015 09:26 PM
Crystal Mod A9L (long story) TomR Engine Management Systems 19 02-28-2015 01:09 AM
AFM PMS series IV darknotch Electronics and Entertainment 15 12-23-2014 01:31 AM
A9P WOT spark advance thunderjet302 5.0/5.8 Engine Tech 10 07-15-2014 07:51 PM
