16 injectors, can I run 2 injectors from each driver - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 8 Old 01-25-2016, 05:54 PM Thread Starter
Ok , 408 Windsor with 6 71 blower . I want to run 42 lb injectors below the blower and 24 lb injectors above the blower.
This way the majority of the fuelling is sequential port injection and the smaller injectors above the blower just keep the mixture through the blower wet, which is what it needs. I'm running stock 95 mustang ecu with PMS . Is it ok to run two injectors off each wire
uk blowers is offline
post #2 of 8 Old 01-26-2016, 09:19 AM
I 'believe' the basic MS2 from DIY autotune comes with 2 low impedance Injector drivers, which is adequate to run 8 injectors in wasted spark! To run 8 injectors sequentially you will need to ad an additional 2 injector drivers, which could alternately run 16 injectors in wasted spark. Beyond that im unsure! the thing With MS is, RTFM!! The manual is your friend. Read it cover to cover and then read it again, None of it will make any sense until you actually start applying it with hands on! It takes alot of patience and ALOTTTT more caution BUT once you getting up and going and all the bugs worked out you will likely no more about electricity, engine tuning, and cars in general then you would if you were to attend and graduate UTI! Other standalone systems can then be figured out realativly easy as the basic principles are the same, just a different interface! Just remember when in doubt DO NOT POWER IT UP!!!
at8tc is offline
post #3 of 8 Old 01-26-2016, 12:36 PM
Paulie's Avatar
No you will likely fry the injector drivers in the stock ECU. Maybe a low impedance injector driver like a versafueler would work.
Paulie is offline
post #4 of 8 Old 01-26-2016, 12:40 PM
lol whoops i thought this was megasqsuirt lol! ya dont go plugging extra stuff into a factory ECU
at8tc is offline
post #5 of 8 Old 01-26-2016, 03:30 PM
Yes you can but you must wire the injectors in serial, not in parallel.
Megasquirt
seijirou is offline
post #6 of 8 Old 01-26-2016, 05:23 PM Thread Starter
Could you explain why in series and not parallel , thanks
post #7 of 8 Old 01-26-2016, 09:07 PM
TomR's Avatar
I would never run them in series. If you run them in series, voltage to each injector is half **IF** the injectors have equal impedance. If they have unequal impedances, which is likely if they are mixed types, the injector with the lowest impedance will get the least voltage.
This means the injector that needs the MOST voltage to build flux will get the least voltage.
Also, current will be decreased.
The very best you could hope for would be each injector having 7 volts and sluggish opening. The worse is one injector in the series string would never open.
If you run them in parallel the voltage is perfect but they would draw the sum of current through each injector. Since the Ford ECU, like every ECU I have seen, uses an open collector output, for about $50 maximum US you could buffer the output port. You would need 8 PNP power transistors and eight small resistors. The emitters of the PNP would go to the injector leads that formerly went to the ECU. The bases would go through a small resistor to the appropriate ECU pin, and the collectors to power ground.
The external power transistors would take all the injector current. Something like this:
MJ15004G ON Semiconductor | Mouser
or this
MJW1302AG ON Semiconductor | Mouser
Each could be bolted directly to an aluminum plate for a heat sink. Then you could just run injector impedance down to about 1 ohm.
TomR is offline
post #8 of 8 Old 01-26-2016, 11:42 PM
redlightningssf's Avatar
no fried injector driver here AKCO ford computer has been fine for years.
2016 V6 Mustang Race Red
redlightningssf is offline
For Sale trickflow 95lb low imp. injectors & aem 10 channel inj. driver module an harness stangerpower Fuel System & Related 4 06-23-2012 08:40 PM
For Sale ➫➫➫ 03/04 Cobra Part out Black & Torch Red ➫➫➫ 2003snake Modular Engine Parts 329 10-09-2011 10:39 AM
For Sale 42 LB Summit # Sum-240042 INJECTORS 1Hour of Run Time 1FAST LX Fuel System & Related 2 09-27-2011 02:13 PM
Want To Buy 160lb injectors & driver 97QUICKSNAKE Fuel System & Related 2 04-15-2011 07:35 PM
For Sale Low Impedance Injector Driver AEM & 96lb injectors Jerry89supercharger Fuel System & Related 6 03-18-2011 12:05 AM
