calibrated PMAS? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 12-23-2015, 10:11 AM Thread Starter
Trader Feedback: (21)
calibrated PMAS?
OK here'smy deal, I am putting together a new turbo setup, I have new 55# injectors, and a new blowthrough PMAS that is calibrated for 50# (that is the size I originally intended to use) I am going to be using my tweecer for tunning. How will I make this work, tweecer adjustments? Recalibration of maf? Tride calling PMAS 15 times and no answer and no replies to my emails! I'm needing some guidance here, thanks all!
boostup89 is offline
post #2 of 2 Old 12-23-2015, 12:28 PM
Paulie's Avatar
If you are using your tweecer enter the actual maf transfer function of your meter and the injector specs for your 55# injectors.
Paulie is offline
calibrated PMAS? boostup89 Turbochargers 4 12-30-2015 05:10 PM
PMAS 80mm MAF calibrated for 24lb injectors thunderjet302 5.0/5.8 Engine Tech 7 05-14-2015 12:48 PM
For Sale Pmas MAF calibrated for 85lb injectors mguinn Fuel System & Related 3 01-12-2015 07:04 PM
For Sale PMAS 95mm Mass Air Meter calibrated for 60lb injectors and set of calibrated 60 lb in bjs01 Fuel System & Related 0 04-29-2014 11:30 PM
For Sale 60 lb injectors and Calibrated Pmas: gaging interest mhinchley Fuel System & Related 4 06-08-2011 05:36 PM
