Looking to tune my own setup, what setup do you recommend that is user friendly and easy learning curve? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 33 Old 11-20-2015, 12:33 AM Thread Starter
machine head's Avatar
I'm tired of paying an arm and a leg to have my car dyno tuned. I want to tune it myself. I currently have a sct flip chip. What setup would you recommend that is user friendly and doesn't require a Ph.D. to operate?
machine head is offline
post #2 of 33 Old 11-20-2015, 09:56 AM
What year Mustang is this for, and what engine?
Matt Cramer
Matt Cramer is offline
post #3 of 33 Old 11-20-2015, 11:57 AM Thread Starter
1993 mustang 410"w
post #4 of 33 Old 11-20-2015, 03:07 PM
steelie4u's Avatar
im running a 408 in my 93 stang and use the PRO-M system, its pricey but its also very good, comes with all new wiring harness its a good system with a lot of adjustable parameters and the support is top notch I don't use coil on set up buts its available from them. There support is top notch just search here for pro-m there's videos and lots of discussion on it
steelie4u is offline
post #5 of 33 Old 11-20-2015, 08:29 PM
Trader Feedback: (26)
Pro-M also
dragking is offline
post #6 of 33 Old 11-21-2015, 09:27 AM
pkstang's Avatar
Trader Feedback: (161)
same here.. cop, oem like harness and oem based ecu
pkstang is offline
post #7 of 33 Old 11-21-2015, 11:53 AM
modo's Avatar
also a pro-m user but with a distributor. car never ran better
93 GT
66 Coupe
modo is offline
post #8 of 33 Old 11-22-2015, 01:49 AM
dj94gt's Avatar
Holley HP or Dominator EFI depending on features you need. The software is one of the easiest to operate, and you can find support on nearly every major forum.
dj94gt is offline
post #9 of 33 Old 11-23-2015, 06:10 PM Thread Starter
So a lot of you guys are running Pro M. I don't want to have to run individual coils or crank trigger. I just want a plug n play unit easy to learn. Is Pro M like that? How much do they go for? I'm just running a 410"w with 250 shot with a c4 so I want to be able to tune for that.
post #10 of 33 Old 11-23-2015, 07:28 PM Thread Starter
I watched the Pro-M efi videos and WOW that's definitely want to go with it.
So I can sell my MSD digital 6 box right? What about my HVCII coil. Is that alright to keep?
post #11 of 33 Old 11-23-2015, 08:14 PM
modo's Avatar
keep the coil and the ignition box depends on boost and how much i would imagine. i have not tried running mine without the 6al. when the box finally goes i will
as far as your plug it in and go question goes that is how mine has been since day one. installed the harness, widebands, input the required data and literally have been enjoying the car since. same with the meth setup, just input the settings as directed and i added 1 more degree of timing instead of the defaults.
i have a thread somewhere that i plan on updating and posting a few videos.
93 GT
66 Coupe
modo is offline
post #12 of 33 Old 11-24-2015, 10:44 AM
1993 mustang 410"w
We have a setup that plugs directly into the factory wiring on these cars.
MegaSquirtPNP G2 EEC4A8 for 86-93 Ford Mustang 5.0 DIYAutoTune.com
Plug it in, run a vacuum line for the MAP sensor, and you'll need to set your injector and engine size in the tune, but after that, it's ready to fire up and start tuning.
Matt Cramer
post #13 of 33 Old 11-27-2015, 02:28 PM Thread Starter
After more research I think Holley HP EFI is the setup for me. I really like what I've read and seen.
post #14 of 33 Old 11-27-2015, 03:40 PM
Decipha's Avatar
ford your mild little setup your probably better off just sticking with the factory ecu, its more than capable of handling your setup and its much much cheaper faster and more reliable
buy yourself a quarterhorse from moates.net and drop in the a9l2 tune, significantly less work that swapping ecus and wiring and you should have a driveable car in minutes no problem
A9L2 / EFIDynoTuning
you can go ahead and download the software and tune free from that link above and see if you like it
Decipha is offline
post #15 of 33 Old 11-27-2015, 04:31 PM Thread Starter
Working in a deal for a Vortech V7 YSI. That would work better with Holley HP efi you think?
post #16 of 33 Old 11-27-2015, 04:44 PM
TomR's Avatar
The best thing I ever did with engine controls is the Holley HP. I'm running 25psi boost and never once did I have an issue once I got beyond Holley's ground loop problem.
The ground loop was an easy fix. I just grounded the EEC to the chassis right near where Ford did and where the block head ground is. Once I did that, and pulled the battery negative post EEC lead to the trunk battery, everything was fine. System is flawless.
I'm doing 1.3 60 ft times and running the Ford TFI dizzy with a CD ignition. I have a Bosch MAP/MAT sensor in the elbow, Ford TPS, and the rest came with the Holley kit.
I have the digital Dash.
It is an easy swap, and the best thing I ever did. I did a 20 mile street ride with no issues, and later in the day ran low fives with no changes.
TomR is offline
post #17 of 33 Old 11-27-2015, 07:28 PM
modo's Avatar
i have a ysi / pro-m / methanol. works flawless
nothing at all wrong with the holley and it was my other choice besides the pro-m. here is my worthless .02. if you go holley don't get the hp but the dominator. main reason i say that is you really want to run dual widebands and possibly the additional inputs
even with my old computer (aem ems) i ran dual widebands. i knew i had a weeping mls gasket from the datalogs well in advance before something catastrophic could have happened.
93 GT
66 Coupe
modo is offline
post #18 of 33 Old 11-28-2015, 09:40 PM Thread Starter
Ur right, Dominator would be a better choice.
post #19 of 33 Old 11-28-2015, 10:31 PM
Michael Plummer's Avatar
Trader Feedback: (87)
Back in May 2015 you started this thread: What's the BEST user friendly tuning software for 93' mustang?
https://forums.corral.net/forums/engi...3-mustang.html
Now 6 months later you started this thread: Looking to tune my own setup, what setup do you recommend that is user friendly and easy learning curve? Did you not get the information you were looking for 6 months ago or did you forget?
849rwhp and 771rwtq SAE
Pro-M Racing EMS
Michael Plummer is offline
post #20 of 33 Old 11-29-2015, 07:48 PM
Just Chuck's Avatar
1989 LX 5.0 - 333 Mexican block, Eagle 4340 neutral3.25" crank, Probe SRS 9cc dome .040 psitons AFR 185 Comp heads, FTI HR cam 239/244 613/613, Edelbrock Victor 5.0, 90mm TB, BBK 1 3/4, C4 and 4500 Circle D converter, 4.10 gears
2012 GT/CS 5.0 - Yellow Blaze Tri-Coat metalic, A6, HID.
Just Chuck is offline
post #21 of 33 Old 11-29-2015, 07:57 PM Thread Starter
Michael Plummer...No I did not forget. U cyber stalking to know what I posted 6 months ago???
6 months ago my engine was together and I was looking for the ability to tune using my stock ECU, now I'm building a 427"w with YSI and I looking to ditch my stock ECU and its wiring while I clean up my engine bay. I also thought stand-alone efi systems cost a lot more than they do. Then upon reading and watching videos I learned about the self learning. That's when I decided to go Holley efi.
94' Mustang Cobra #2524
1 of 333 Rio Red w/ Black interior•FORSALE•
color="black">MOTORCYCLE DRAG RACING LOWERING STRAPS & CALIPER BRACKETS
post #22 of 33 Old 11-29-2015, 08:17 PM
Like I posted in your other thread, I just remembered posting in a similar thread and I checked the threads I had posted in, that is all. Congrats on narrowing it down to the Holley. I have a few friends who run the Holley with great success, so I'm sure it will work great for you too.
Pro-M Racing EMS
post #23 of 33 Old 11-29-2015, 08:23 PM Thread Starter
Thank you. I'm sure all the major brands are very similar. I first was going to go with Pro-M but guy I know has the Holley HP and was telling me about it and he knows that system inside and out and lives near by so that how I picked that one. He runs 8.60's on 93/meth and is a street car. So he define toy know what he is doing.
post #24 of 33 Old 12-08-2015, 09:35 PM
dj94gt's Avatar
Excellent choice. I have several customers up in your area that run HEFI. One of which many members here will know - Freezy finally got swapped over to it this year. Great success too!
dj94gt is offline
post #25 of 33 Old 12-08-2015, 10:33 PM
GilroyRacing's Avatar
Trader Feedback: (111)
Originally Posted by Just Chuck View Post
Stop making fun of Alex
91 Fox
R.I.P. 347: 1.43 60' [email protected] 1/8th [email protected] 1/4
302 1.59 60' [email protected] [email protected]
GilroyRacing is offline
post #26 of 33 Old 12-11-2015, 08:19 AM
irwinner's Avatar
Trader Feedback: (47)
I chose the HEFI system. I've never tuned a thing before and I got my car started and driving with no problems. WOT was effortless to tune. Download the software and play with it first, you'll see how easy it is to navigate.
All of this was without a base tune (guy I bought it from never provided one, even though he said he would). For support, look at the holley forums.
306 - RIP - 12.01 @ 117.2....
408w AFR 220, Ported Super Victor, FTI Cam, Holley EFI
irwinner is offline
post #27 of 33 Old 12-12-2015, 08:46 PM
US Army Retired
Chris94GT's Avatar
I run an MSPNP2 on my 410.
Do you want easy and cheap
or easy and best
and is installing part of the easy part you are looking for or do you just want easy to tune?
94 GT
Chris94GT is offline
post #28 of 33 Old 12-13-2015, 01:34 AM
BMF347's Avatar
Stinger performance pimp ecu. Uses stock 5.0 harness and sensors. Also connects via the factory ecu plug. Lots of options if you add nitrous or boost of any kind. 700$ and uses tuner studio software. Tech support from the developers and users is second to none and available 24/7. Great product and easy to install. Has an auto tune feature which works very well also.
_______________________________________________
-1986 LX T-Top - 351w, TKO500, Powerdyne XB-1A
-Farewell to the other 10 projects I've had to part with
BMF347 is offline
post #29 of 33 Old 12-15-2015, 08:59 PM Thread Starter
What is the Holley HP EFI part number that I will need?
Do I need to purchase any other wiring or components to work with my MSD billet distributor?
I'm looking to plug-n-play.
I removing my factory wiring harness since its 22 years old and I want to eliminate the chance of faulty wiring down the road. This way I can take my time and route Holley's wiring harness how I want it for a more appealing look under the hood.
post #30 of 33 Old 12-15-2015, 11:21 PM
dj94gt's Avatar
SBF kit is 550-606 or 550-606N (N designates the NTK wideband O2 sensor)
If you have the billet TFI distributor you will need the 558-305 TFI ignition adapter. If you want to turn on an electric fan, or any other input/output you'll need the 558-400 I/O Harness.
dj94gt is offline
post #31 of 33 Old 01-01-2016, 10:46 AM
freezy74's Avatar
Trader Feedback: (30)
I would not be happier with how the system has performed. And having you as my Holley tech support has helped also. Thank you for getting me where I am today with this system...
[email protected]
Holley EFI
Conventional thinking yields conventional results
freezy74 is offline
post #32 of 33 Old 01-01-2016, 02:53 PM
dj94gt's Avatar
You're welcome. Customers like you make my life easier.
dj94gt is offline
post #33 of 33 Old 01-02-2016, 08:06 AM
freezy74's Avatar
To a degree lol...
[email protected]
Holley EFI
freezy74 is offline
