speed density tuning - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-10-2015, 08:43 AM Thread Starter
Hi, I have an 86 5.0 that I just purchased, pulling the motor to pull apart and reseal, motor has upgraded heads, upper and lower intake, cam and bigger injectors 24lbs, car doesn't seem to run 100% with the vehicle still being speed density it would need to be tuned with all these parts on it correct? I was considering once I put the motor back in to send the vehicle to get a proper tune. I live outside Philadelphia pa and was wondering if anyone knew anybody that could tune speed density in my area?
ginger123 is offline
post #2 of 2 Old 11-16-2015, 03:52 PM
Yes, it would need a tune if you put 24 lb/hr injectors on it. Is it using a totally stock ECU, a chip, or some sort of aftermarket ECU?
Matt Cramer
Matt Cramer is offline
Want To Buy fb2 speed density 4 cylinder foxbody ecu for 5 speed kevin st.clair Electronics and Entertainment 1 06-07-2013 01:14 PM
For Sale 86 GT Speed Density Harness and Computer fastyam5 Electronics and Entertainment 5 02-03-2013 09:04 AM
Converting from mass air to speed density? 95Stangco Engine Management Systems 2 10-16-2012 12:06 PM
88 Turbo mustang speed density to mass air Viper_Hunter Turbochargers 0 11-16-2010 02:26 PM
Speed Density EFI with Explorer/GT40 Heads n Intake 347gt General Mustang Tech 9 11-07-2010 08:46 PM
