Going Stand Alone - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 09-01-2015, 01:59 PM Thread Starter
Onequik89's Avatar
Going Stand Alone and Have Some Questions
Going to a stand alone system like the F.A.S.T. or Holley system very very soon in my 89 GT with a 331 EFI with a Vortech. I want to keep things like turn signals, horn, power windows, and power locks. My question is any of that controlled thru the stock ECU or can i pull the ECU and complete engine harness out or do i need to leave the ECU and part of the harness in the car? I know the power locks get their power from the solenoid but unsure about the rest.
Onequik89 is offline
post #2 of 10 Old 09-01-2015, 04:08 PM
Saleen414's Avatar
I run a Fast XFI on my car. The entire engine harness and ECU can be removed. None of the other electrical systems on the car are run by the ECU.
26 X 8.5 Hoosier
Saleen414 is online now
post #3 of 10 Old 09-01-2015, 06:04 PM
boostdcoupe's Avatar
Trader Feedback: (30)
arent some of the stock gauges fed by the stock harness?
replaced the 93'ish coupe with a 76 F100, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, AOD, Edge custom conv., Silverfox SPT-MAC-TB.
boostdcoupe is offline
post #4 of 10 Old 09-02-2015, 07:06 AM Thread Starter
Onequik89's Avatar
I'm putting in an electronic dash so im not too worried about the gauges. Yes some of them get readings from sensors on the motor.
post #5 of 10 Old 09-02-2015, 08:16 AM
TomR's Avatar
I thought about connecting my OEM dash gauges, and I even built an interface board, but I decided to use the Holley digital dash.
I made a cluster with LED idiot lights that also has two red LED three digit displays instead. This way I still have a blue bright light, turn signal, and multiple warning light indicators.
My battery is on a large 3 digit meter and has a red or green LED above it. It is green when charging, blank when anything below charge voltage down to about 75% charge, and red when less than 50% charge.
I haven't decided what to use the second three digit display for. Likely water temperature or fuel.
I put 5 or 6 LED's (that can each be red, yellow, or green) across the center. They can be triggered from the Holley, or they can independently operate from the Holley sensors. They bridge the sensors with hundreds of thousands of ohms impedance, so they cannot affect sensor function.
I find warning lights much more effective than gauges, the only gauge I watch is a tach.
TomR is offline
post #6 of 10 Old 09-02-2015, 09:29 AM
Yes, but the only one that ties into the engine controls is the tach, which gets a signal from the TFI module. If going distributorless, most ECUs have a tach output anyway.
The other gauges have separate sensors that do not tie into the ECU.
Matt Cramer
Matt Cramer is offline
post #7 of 10 Old 09-02-2015, 04:24 PM
Saleen414's Avatar
With the Fast XFI you have to run an aftermarket ignition box to trigger the ignition anyway. All of the aftermarket ignition boxes have a tach output. You would just take the tach wire from the stock harness and run it to the aftermarket box, just like you would do if you installed an MSD or other ignition box to a stock Mustang.
Also the Fast system uses GM ECT, ACT, and MAP sensors. The IAC is also different. Whatever you do, DO NOT power up the Fast system with the IAC disconnected. It WILL fry the Fast ECU. Sometimes it is only a $125 repair (plus shipping) other times you smoke the whole ECU. Ask me how I know.
26 X 8.5 Hoosier
post #8 of 10 Old 09-02-2015, 05:57 PM
TomR's Avatar
Why on earth would disconnecting the IAC damage the FAST system? That makes no sense at all. If an open load damages it, they have a serious hardware design issue. A good system would be protected for shorts, but it really takes a big hardware error for an open port to cause damage.
TomR is offline
post #9 of 10 Old 09-03-2015, 06:42 AM Thread Starter
Onequik89's Avatar
I agree TomR. I do not see how an open load like an IAC will fry and ECU. The holley system you can run it with or without the IAC with no issues. Can you PM when you get some time please TomR? I have read thru your thread putting the Holley in and have some questions I'm sure you can help me with.
post #10 of 10 Old 09-03-2015, 10:50 AM
Saleen414's Avatar
I asked this very same question. I was stunned that it was designed that way, but it is. I work on a lot of different makes of cars from around the world and if a car comes in with a high idle problem, one of the things I do is unplug the IAC while it is running to see if the high idle is being commanded by the ECU. It helps point me in the right direction with the diagnosis. I tried that with the Fast system and smoked the ECU. I called them about it, and they just said that is just the way it is, and Duh, don't do that again. I personally don't understand why anyone would design it that way. It makes no sense at all. Lucky for me it was a $125 repair, and I did not have to shell out the over $1K for a new ECU.
26 X 8.5 Hoosier
