Best ez-efi system for high hp 2v - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 08-25-2015, 11:47 PM Thread Starter
Looking for a self tuning stand alone setup for my 99 mustang gt. 20+ psi from a novi 2000 with a plate kit on top. Looking for the best money can buy and not have too pay for any custom tuning. Thanks in advance!
1999 mustang gt,Fully forged shortblock,Patriot cncd heads,Comp 270 cams,60# injectors,Bbk 315 lph pump,jms fuel max v2,Novi 2000 with Paxton a2a intercooler,3.25 upper,Innovator west 15% crank pulley,T-45 with spec stage 3 clutch,3.73 gears
Dennis5374 is offline
post #2 of 4 Old 08-26-2015, 04:47 AM
SPEEDLINE's Avatar
I think any self tuning software (with A/F input) will be only for normal light load driving. Any high load (WOT) driving and you will have to set up manually.
Atleast this is how I see a lot of aftermarket computers on the market. Please do chime in pro's if im wrong.
SPEEDLINE is offline
post #3 of 4 Old 08-26-2015, 06:37 AM
Wicked03GT's Avatar
Trader Feedback: (50)
Holley EFI has those options, but installing that in your car would require a retro fit that replaced a lot of the stock equipment or lay the new EFI kit over the exisiting wiring somehow to power all the support equipment and keep all the standard ignition and stuff.
Wicked03GT is offline
post #4 of 4 Old 08-26-2015, 08:49 AM
You're going to want to put that thing on a dyno to tune the spark table any way you slice it. There's no good self tuning option for finding optimum spark timing on a blower motor. For your build, you will be better served by hiring the best tuner money can get rather than the best self tuning system - a good dyno tuner is going to be way ahead of the computer.
Matt Cramer
Matt Cramer is offline
Fuel System for carb. to EFI conversion? mulage 5.0/5.8 Engine Tech 0 10-01-2012 07:11 PM
For Sale Fast Classic EFI system TFI mustang347strokeme Electronics and Entertainment 6 11-11-2011 01:21 PM
For Sale NEW FAST Classic EFI Standalone System w/Dual Sync Distributor foraye Fuel System & Related 1 06-13-2011 03:50 PM
For Sale efi system setup for boost, complete kellam Windsor Engine Parts 2 01-15-2011 11:43 AM
For Sale NX EFI system okhatch Power Adders 6 12-17-2010 04:19 PM
