Fuel Injector Question - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 07-14-2015, 12:24 AM Thread Starter
Ok guys, Im not sure this is the right section but i'll give it a whirl anyways.
Engine Management seemed like the best place to go.
I have done a fair amount of research and am getting mixed signals and a little confused to be honest. I'll try to give as much info as possible so hopefully you guys don't have to do much searching.
I'm looking at getting a set of 24lb injectors for my 1990 5.0
I understand that i'm looking for the blue injectors, but Im not sure which to go with.
Im looking at the "blue TOP" injectors bosch # 280150947
the entirely blue injectors bosch # 280155715
Both are supposed to be 24lb and i believe the jetronics (ev1) style connector.
The blue top are the fatter injector and the blue body are the slimmer.
Will both fit stock harness and fuel rail?
If so, i will just go with whichever I can find cheaper.
_Grady02 is offline
post #2 of 3 Old 07-14-2015, 09:17 AM
They'll both fit.
Megasquirt
seijirou is offline
post #3 of 3 Old 07-15-2015, 11:09 AM
EV1 and EV6 are the same. Might need the conversion clip, check what they use.
I'm using EV14, and everything is different. But only took me a couple hours and the job was done.
Hope this helps
Meegs is offline
Car shut down while driving and will not restart, HELP! shdowconspiracyx 5.0/5.8 Engine Tech 15 09-10-2012 02:31 PM
fuel pressure prob. juiced418 5.0/5.8 Engine Tech 8 11-10-2011 05:05 PM
Fuel Pressure & injector sizing mghoward74 Turbochargers 9 10-21-2011 11:41 AM
car drops fuel presure at 5800rpm, need help 98muscrat Superchargers 44 06-15-2011 11:22 AM
