Tune problem with Quarterhorse - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 07-12-2015, 08:01 PM Thread Starter
Does someone want to take a look at this tune file. I wont get into a lot of detail but it was written and the car bucks unless your applying pressure to the throttle. AFR reads 14.0 while driving so I guess that is correct and the other night I was in boost and though I heard some detonation. I have gotten a data log and the timing is all over the place. It threw a check engine light so I pulled codes and its an O2 code, though I do not have them installed. I am putting them back in and Ill see from there I mailed the guy who tweaked the tune and.... well there it is, been almost a month tired of waiting.
I cannot upload the data log or tune file so I guess if you want to give it a go I can email it to you.
The car is the car in my sig that it is being used for.
Thanks,
Eric
[email protected]
Black 93GT, Single Precision 7675, 308 Mexican block, F cam, AFR 195's, 75mm TB, 1.7RR, 60's, BA5000 MA, Crane Hi-6, LX-92 Coil, S/N 95 Rails, Kirban FPR, 255 inline/255 intank, aluminum radiator, Countour Fan, Police Oil Cooler, 3.31 gears and a 5 speed.
post #2 of 5 Old 07-13-2015, 12:07 AM
indy2000's Avatar
email sent
indy2000 is online now
post #3 of 5 Old 07-13-2015, 11:47 AM Thread Starter
I didn't get an email.
post #4 of 5 Old 07-13-2015, 01:18 PM
fox88's Avatar
Do you have your adaptives enabled? Curious, because without O2's, you would be chasing your tail for sure.
FTI TW heads/FTI cam/RPMII/A-trim/T5 & 4.10's/QH w/ BE & EA/GUFB
www.carstereooneinc.com
fox88 is offline
post #5 of 5 Old 07-13-2015, 01:24 PM Thread Starter
I was and still am using an innovate wideband. I am single turbo and all the bungs are welded in the downpipe.
Loss of power after 3k RPM problem SprayN GT & SOHC 7 10-08-2014 10:56 AM
Baseline Tune Problems stevenminix EEC Tech 4 08-27-2014 07:24 PM
Help: Steering Problem - 2012 Boss 302 domesticpower S-197 Mustang GT (2011-2014) 4 06-25-2014 12:43 PM
Help: Steering Problem - 2012 Boss 302 domesticpower Road Racing/Auto X 10 06-23-2014 07:55 PM
Whipple tune and SCT tune CtCobra50 Superchargers 9 01-08-2013 07:54 PM
