Timing at idle causing too get hot fast - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 06-20-2015, 08:14 AM Thread Starter
sprayed347's Avatar
I have a 93 lx with a 306 9.8to 1 edelbrock performer heads cobra intake.on3 kit f cam moates with b.e.has a large alum. Radiator and cooling fans.this thing gets to 180 in less than 10 minutes of idle time.Iam re wrapping all the pipes.but I took a data log of it just idling from start to 180 to confirm guage accuracy.noticed air fuel was 14.5 to 14.9 and timing was at 30 deg the whole time would a little more timing and fuel at idle help combat this getting hot fast issue?it seems lean with not enough timing to me.but iam no tuner.
sprayed347 is offline
post #2 of 5 Old 06-24-2015, 02:10 AM
toyman's Avatar
I'm missing something. Getting up to operating temperature quickly should be a good sign. What is your concern?
Richard
KB 2.1L @ 9psi, FRPP M5400-A Suspension System, FRPP Aluminum D/S, Built AODE and TC, FRPP 3.73 Gears, Balanced Roller Cammed Engine, Edelbrock Performer Heads, Comp 270AH cam, AEM EMS, 3.5 Bar MAP, Zeitronix ZT-2 WB, FRPP 70mm TB, modified UPR CAI, Be Cool Aluminum Rad
toyman is offline
post #3 of 5 Old 06-30-2015, 09:06 PM
Not enough info, what dist are you using? any advance? like vacuum or the spout? total advance should not be more than 34. at idle if the timing is to far retarded, it will run hot, but 180 is not hot. If you have a dist with only mechanical advance then 15 -17 degrees at idle is good, but this also depends on the dist set up, and what total advance is. See what I mean, not enough info.
K8WDX is offline
post #4 of 5 Old 07-03-2015, 01:44 AM
14.5 - 15.1 Idle/Cruise is perfectly normal. That's what my A9P did.
I've had factory vehicles wait to turn on cooling fans until 219F (NA Iron block, Alum heads, 10.0 compression, 87 Octane)...so the temp is fine.
180F in 10 mins is absolutely normal.
Not sure on the timing curve.
bsfguy is offline
post #5 of 5 Old 07-09-2015, 01:34 PM
Nothing wrong with what you're describing. That AFR is perfectly fine. 30 degrees advance is a bit much for idle but probably won't hurt anything. I certainly wouldn't increase it.
Megasquirt
seijirou is offline
Code 91, and engine wont idle after spinning it with coil disconnected... scld1354 General Mustang Tech 12 06-03-2014 01:09 AM
Timing, advance, distributor, ignition ?'s bolt-on-bandito General Mustang Tech 21 02-11-2014 12:19 PM
erratic idle hot or cold SVOJOE 5.0/5.8 Engine Tech 4 05-26-2011 11:07 PM
Engine will not go into fast idle when started cold, causes? FormerlyBlue88Notch 5.0/5.8 Engine Tech 5 03-10-2011 09:27 AM
Engine Dieseling, Fast Idle when hot! cward8 5.0/5.8 Engine Tech 2 12-20-2001 10:09 AM
