1992 intermittent starting issue - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 19 Old 06-08-2015, 05:05 PM Thread Starter
I'm looking at buying a 1992 LX 5.0L convertible. But it is having a starting issue most of the time starts first time but recently sometimes doesn't start at all pump is priming there's pressure in the lines. Some one suggested the ecm might need to be repaired or replaced any suggestions?
droptopg is offline
post #2 of 19 Old 06-08-2015, 08:26 PM
indy2000's Avatar
so it cranks
and won't start sometimes?
cold, hot?
indy2000 is online now
post #3 of 19 Old 06-08-2015, 09:27 PM Thread Starter
It's. Starts after cranking it 4 or 5 times only once it didn't start and waited like an hr and it started. It happens sometimes in the morning also after its been running and u stop some where for 10-20 mins
droptopg is offline
post #4 of 19 Old 06-08-2015, 09:52 PM
indy2000's Avatar
there is
CRANK no start
and no crank
if this is a crank no start, you are missing one or more
spark proper time
fuel proper time
compression
start with spark
again
does it do it warm, hot or cold???
no idea what "morning' or '10-20mins' is
be specific
post #5 of 19 Old 06-08-2015, 10:39 PM Thread Starter
It does it hot it does it cold.
It does not turn over on the first time like it used to I have to crank it 3 or 4 times before it turns over and starts so it's getting worst. Sorry if I'm doing a bad job explaining
droptopg is offline
post #6 of 19 Old 06-08-2015, 11:42 PM
indy2000's Avatar
put a fuel pressure gauge on the rail, and record what the pressure is at crank.
3-4 revs,,,,is NOT a problem.
post #7 of 19 Old 06-09-2015, 12:18 AM Thread Starter
It's 35psi
First crank revs 5-6 times so I stop and recrank revs 5-6 times then might start the third crank or do the same and start on the 4th crank
Could it be a pip sensor?
droptopg is offline
post #8 of 19 Old 06-09-2015, 12:22 AM
indy2000's Avatar
no pip will be no start
you have a start, just long crank
your pressure should be near 40psig.
if you want to test pip.
use a dvom, and test pip, should be around 4volts at crank.
post #9 of 19 Old 06-09-2015, 12:51 AM Thread Starter
Also I have realized it's been hot here like 30 degrees so it's been happening when its hot
droptopg is offline
post #10 of 19 Old 06-09-2015, 01:22 AM Thread Starter
Any suggestions if not the pip
droptopg is offline
post #11 of 19 Old 06-09-2015, 09:09 AM
indy2000's Avatar
pip is good
fuel pressure is good
you are good to go
post #12 of 19 Old 06-10-2015, 10:14 AM
Trader Feedback: (26)
my sons car did this. replaced tfi module and pip still acted up. ended up being ecm. took cover off had a burnt spot on the circuit board.
dragking is offline
post #13 of 19 Old 06-10-2015, 07:50 PM
indy2000's Avatar
long crank from a bad ecm?
don't see it.
post #14 of 19 Old 06-10-2015, 11:06 PM Thread Starter
Ok so tfi been replaced swapped a distributor to check to see if it was the pip sensor still didn't solve the problem 40psi fuel pressure and holds at 35 when cranking
droptopg is offline
post #15 of 19 Old 06-10-2015, 11:30 PM
indy2000's Avatar
you just like changing parts?
post #16 of 19 Old 06-10-2015, 11:46 PM Thread Starter
If it will help rule out things yes
droptopg is offline
post #17 of 19 Old 06-10-2015, 11:55 PM
indy2000's Avatar
of course, its only time and money.
but does not make you any better and diagnosing.
post #18 of 19 Old 06-12-2015, 02:13 AM Thread Starter
That's why I was asking for help and clearly your suggestions didn't help and thanks dragking it was the ecm
Indy2000 as I said from the beginning it was a car I was looking to buy so these were things that were switched out by the current owner
droptopg is offline
post #19 of 19 Old 06-14-2015, 10:59 PM
glad you found it. sometimes it takes a few replacement parts to figure it out, especially parts that are known to be problematic like tfi.
dragking is offline
Need Help With Starting Issue Nolan592 General Mustang Tech 6 05-31-2014 12:38 PM
Starting issue 1993 5.0 Mstng93SSP General Mustang Tech 6 11-27-2013 01:24 PM
1992 Twin Turbo LX Hatch Charged97 Mustangs For Sale/Wanted, 1987-1993 68 02-11-2013 04:56 PM
Help with starting issue 07BlackStang 5.0/5.8 Engine Tech 0 06-19-2012 10:45 PM
Help with classic Stang starting issue stangman39 Lounge 4 02-18-2011 11:38 AM
