binary editor and eec analizer - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 05-30-2015, 10:13 AM Thread Starter
sprayed347's Avatar
Iwant to view a datalog does ea have to be registered to view a datalog ? is there any free and easy way to do this?
big cox racing
sprayed347 is offline
post #2 of 6 Old 05-31-2015, 07:58 PM
I'm just getting into tuning myself and I believe you have to purchase the license.
Shaun351 is offline
post #3 of 6 Old 05-31-2015, 08:31 PM
bunso's Avatar
You need to go to EFIDYNOTUNING.COM and all the binary editor help you need is in there. Tons of great info in there. You can always get with Decipha on there to help you out on any issues you come across
93 coupe.10:1 331 stroker,holley aluminum heads,lunati 61011 cam,30lb injectors,ported evplorer intake
bunso is offline
post #4 of 6 Old 05-31-2015, 08:33 PM
bunso's Avatar
But to answer your question after you datalog it will automatically save the log on the C drive > Binary Editor > Datalogs
bunso is offline
post #5 of 6 Old 06-01-2015, 03:44 PM
jchav02's Avatar
To look at the logs with BE you have to have a license or dongle. If BE logs without the license you should be able to view them in excel or something similar. I have never tried to log without my dongle plugged in, so I'm not sure if it will datalog without it.
jchav02 is offline
post #6 of 6 Old 06-04-2015, 03:38 PM
Decipha's Avatar
you can open the .csv file with excel its a spreadsheet
i freeze the top column and zoom on down to see the values same as EA
decipha @ EFIDynoTuning
www.efidynotuning.com
Decipha is offline
