Eec help - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 05-20-2015, 09:33 PM Thread Starter
Eec help
Just got done hiding wires on my 92 Gt engine starts runs misses and has cel on it will not let me pull codes the only thing I changed was un wired fuel pump relay and ac relay too fit them through strut tower any suggestions would be apprieciated
Flamed92 is offline
post #2 of 3 Old 05-25-2015, 07:37 PM Thread Starter
Bad computer
I have 92 gt just hide all wires car starts and runs it misses the check engine light is on when runs can not get it to pull codes or go into self test mode is the computer fried? Thanks for any help
Flamed92 is offline
post #3 of 3 Old 06-17-2015, 04:55 PM
EEC issues?
Almost always, any new problem is directly related to work you just performed. If your wiring checks-out, then you might consider bad EEC capacitors. I just replaced 3 of them in my A9S EEC.
Stroked_93_Cobra is offline
WOT Miss 306Guy 5.0/5.8 Engine Tech 29 09-28-2013 09:07 AM
custom wiring the stock eec harness... HELP speedracer1000 Electrical & Wiring 0 06-26-2012 07:12 PM
Possible fried EEC? scott88 General Mustang Tech 10 04-13-2012 10:20 AM
Changing EEC matthewx 94/95 Tech 3 11-26-2011 07:29 PM
