Help me with selecting a cam - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 04-25-2015, 10:44 PM Thread Starter
I have a 92 convertible Mustang GT stick shift,
cold air intake,
upper and lower edelbrock rpm II intake,
Holley Systemax 17deg ( they are the Brodix castings 34R 11875A) aluminum cylinder heads. They use pedestal mount rockers (1.6 ratio roller rockers), 61cc chambers, 175cc intake ports, 71cc exhaust ports, the exhaust is raised .400", 1.94" X 1.60" valves
70mm throttle body and spacer,
70mm mass air flow meter,
Mac shorty headers, 2.5" off road x-pipe NO converters, flowmaster mufflers,
373 gears in rear end
245/50/r16 drag radial tires on chrome ponys,
I weigh about 175lbs.
Will eventually get a supercharger later on down the road and possibly NOS but like I said that LATER down the road. No time soon.
I can't think of anything else to put. If need more info let me know!
Please help me select the best cam for my setup.
Schwers39503 is offline
post #2 of 3 Old 04-25-2015, 11:39 PM Thread Starter
Please!! Anyone out there that can help?
post #3 of 3 Old 04-30-2015, 04:44 PM
GORDIE's Avatar
Contact Ed Curtis at FTI he will help you get your perfect cam selection
Dart Block FORDSTROKERS 347 with a novi 2000 through a Liberty TKO 600
GORDIE is offline
351W cam walk paulsstag 5.0/5.8 Engine Tech 4 06-17-2013 10:11 PM
1.7 rockers w/ stock cam and turbo. mr_minnis Turbochargers 6 02-15-2013 02:09 PM
need help selecting the rite cam for my 306 1 bad stang 5.0/5.8 Engine Tech 6 01-19-2013 03:40 PM
Advice on roller cam for 351w with 1.7's jruppert 5.0/5.8 Engine Tech 0 03-20-2011 11:43 PM
F cam problems... trickflow93gt 5.0/5.8 Engine Tech 26 03-08-2011 09:02 PM
