CLASSIC FAST W/ MSD CRANK TRIGGER - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 6 Old 03-25-2015, 06:33 PM Thread Starter
I HAVE A CLASSIC FAST SEQUENTIAL WITH A MSD CRANK TRIGGER AND A MSD DIGITAL 6 BOX ON MY 93 TURBO MUSTANG. MY PROBLEM IS HOW DO I WIRE EVERYTHING UP AND GET MY CAR STARTED WITHOUT MY 160LBS INJ WASHING DOWN MY NEW DART 331. i HAVE BEEN READING THAT I HAVE TO PUT THE CRANK AT 50 BTDC TEN PHASE THE ROTOR. I NEED STEP BY STEP INSTRUCTIONS ON HOW TO GET THE CRANK TRIGGER SET PROPERLY AND HOW TO USE MY DIST AS A CAM SENSOR. AND HOW TO WIRE THE FAST INTO MY CAR IF THERE IS ANY LINK I CAN GOT TO PLEASE LET ME KNOW THANX ROB
RobU2 is offline
post #2 of 6 Old 04-10-2015, 03:47 PM Thread Starter
WOW no help at all??????
RobU2 is offline
post #3 of 6 Old 04-10-2015, 10:25 PM
Saleen414's Avatar
Fast has an excellent tech forum that you should check out. Plus they have online instruction and wire diagrams. BTW a classic Fast is batch/bank fire EFI not sequential.
26 X 8.5 Hoosier
Saleen414 is offline
post #4 of 6 Old 04-10-2015, 10:27 PM
Saleen414's Avatar
http://www.fuelairspark.com/
Start here
26 X 8.5 Hoosier
post #5 of 6 Old 04-10-2015, 11:11 PM
Ihaitchu's Avatar
Trader Feedback: (36)
I just bought a FAST classic setup and I was told its sequential unless you dont supply a cam signal. Then it fires bank to bank.
Ihaitchu is offline
post #6 of 6 Old 04-13-2015, 06:56 PM
Trader Feedback: (33)
They could be had in either configuration.
1987 Saleen clone: 358cid, FoxLake Vic Jr's, Victor 5.0, YSi, etc, etc, etc
809rwhp on pump gas + meth injection
"Just turn the boost up.....it's only air."
tireburner163 is offline
For Sale MSD 8378 351w Crank Trigger Distributor masterumc Windsor Engine Parts 2 12-29-2014 08:07 PM
For Sale Msd 351w distributor, crank trigger, coil danh9250 Electronics and Entertainment 3 12-14-2013 06:29 PM
Want To Buy Msd crank trigger sbf wanted SickLX5.0 Windsor Engine Parts 5 12-04-2012 11:50 AM
For Sale MSD SBF crank trigger set-up Wildstreet Electronics and Entertainment 5 02-11-2011 11:45 AM
For Sale MSD Crank Trigger Kit ORT2004 Electronics and Entertainment 4 12-06-2010 02:45 PM
