Siemens 80lb injector data? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 17 Old 03-10-2015, 06:07 PM Thread Starter
92rohcp's Avatar
Trader Feedback: (52)
Anyone have the injector data for Siemens 80's.
High slope
Low slope
Breakpoint
15 GTPP OW 2.9L Whipple
SOLD 92LX Dart 363 KB2.8LC Custom A2A with Stinger PIMP EMS 11.4 ET trap 138 MPH no Dyno time.
"The sound is unnatural and not of this world, like a screeching velociraptor with the flames of hell licking it's ass"
92rohcp is offline
post #2 of 17 Old 03-10-2015, 07:07 PM
boostdcoupe's Avatar
Trader Feedback: (30)
click on the chart bro...
80lb/h Siemens Deka 4 Mototron High Imp. (Long Style) USCAR - FI114991Muscle Motors | Siemens Deka Distributor
replaced the 93'ish coupe with a 76 F100, 393, 11.5:1, TEA CNC 205 TW's, custom Hyd Roller, Super Vic, 830 HP, AOD, Edge custom conv., Silverfox SPT-MAC-TB.
boostdcoupe is offline
post #3 of 17 Old 03-10-2015, 07:14 PM Thread Starter
92rohcp's Avatar
I've seen the chart and not sure what's what. Could someone just give me good known injector data they have used.
High slope
Low slope
Breakpoint
92rohcp is offline
post #4 of 17 Old 03-10-2015, 07:54 PM
i dont even know what that stuff is, but isnt it in the first box? with abbreviations below that box?
high slope- .020877
low slope- .028183
breakpoint- .0000242100
post #5 of 17 Old 03-10-2015, 09:34 PM
Trader Feedback: (26)
if i remember right you take the high and low slope numbers that are in the chart and mutiply them by 3600 because they are lbs./sec and you need to convert them to lbs. /hour. this will give you a starting point you will still have to fine tune low slope to your combination even if you use somebody elses numbers. i had to anyway. use the breakpoint number as is .that is how Chris explained it to me. that is how i would go about it.
dragking is offline
post #6 of 17 Old 03-11-2015, 05:37 AM
Michael Plummer's Avatar
Trader Feedback: (87)
Originally Posted by dragking View Post
if i remember right you take the high and low slope numbers that are in the chart and mutiply them by 3600 because they are lbs/sec and you need to convert them to lbs/hour.
Correct.
High slope: 0.020877 x 3600 = 75.1572lbs
Low slope: 0.028183 x 101.4588lbs
breakpoint: 0.0000242100
Checkout Injector Dynamics's injector data spreadsheet for their ID1000's as a comparison for injector data.
1) ID1000 Injectors - Injector Dynamics
2) Click on Sub-menu Plug-N-Play data on the right hand side
3) Click on ID-1000 Ford Characterization tables 8-6-14
849rwhp and 771rwtq SAE
Pro-M Racing EMS
Michael Plummer is offline
post #7 of 17 Old 03-11-2015, 07:03 AM Thread Starter
92rohcp's Avatar
Thanks for the help guys. I understand now, and hopefully someone else can use this data in the future when searching.
92rohcp is offline
post #8 of 17 Old 03-11-2015, 08:40 PM
another thing you have to be careful of, if you set your maf numbers in metric make sure to switch back to english setting when you input slope numbers. took me a little head scratchen to figure that one out. wouldn"t run went back to slope numbers totally different than what i entered! lol
dragking is offline
post #9 of 17 Old 03-12-2015, 11:13 AM Thread Starter
92rohcp's Avatar
Yes that's true, thanks for the comment.
92rohcp is offline
post #10 of 17 Old 03-28-2015, 12:04 PM
pkstang's Avatar
Trader Feedback: (161)
those injectors are 3 times the cost mike...
pkstang is offline
post #11 of 17 Old 06-09-2015, 08:58 PM
1991vert's Avatar
I'm going to pull this back up...I have to enter in injector data into a table that's labeled as Opening Time (ms) vs Battery voltage.
The battery voltage axis has odd values:
8.7
10.4
12.2
13.9
15.6
17.4
19.1
20.9
Not quite sure what to put in for values for the corresponding Opening Times?
Can anyone help me out here?
They don't have the same slope, so not really sure how to figure it out...should I just guestimate?
Thanks,
Chris
91vert: Dart Block, 363 stroker - all forged internals, AFR185s, Trickflow Box-R, 90mm t/b, CI cam, scorpion 1.6's, Kooks 1 3/4" longtubes 3" coll., 3" custom x-pipe, 3" magnaflows w/ tails, 3.73's, Paxton Novi2000, intercooler
670rwhp/655rwtq @ 17psi (belt slip)
1991vert is offline
post #12 of 17 Old 06-10-2015, 12:16 AM
dont really understand what you are asking. if you are trying to enter injector slopes and breakpoint, sounds like you are in the wrong spot.
dragking is offline
post #13 of 17 Old 06-10-2015, 09:30 AM
1991vert's Avatar
I should've mentioned this is for a BigStuff3. There is a table labeled Injector Opening Time. Down on the bottom there is the battery voltage (which cannot be changed) and the input boxes are the opening times (ms). The numbers I listed above are the battery voltages...the input numbers listed for the siemens-deka offset times do not match.
My questions are: Are those the numbers I need? If so, how would I get them dialed in?
1991vert is offline
post #14 of 17 Old 06-10-2015, 10:06 AM
oh, ok. op has pro-m system and was looking for injector slope numbers. if i were you i would start a new thread pertaining to big stuff. think you would get more replies. good luck.
dragking is offline
post #15 of 17 Old 01-26-2016, 01:54 AM
IND9S's Avatar
Trader Feedback: (29)
Correct.
If your using a tuner such as QuarterHorse or Tweecer the breakpoint would be converted to 2.421 as the input value for breakpoint aka FN389.
1992 Mustang LX, Vortech Blown Dart 332..
Originally Posted by huafist View Post
I'd drag my bare nuts through a mile of broken glass just to hear that girl fart through a walkie talkie.
IND9S is offline
post #16 of 17 Old 01-31-2016, 08:21 PM
bunso's Avatar
Go to EFIDYNOTUNING.COM and the injector data is in the reference section. Tons of great data in there
93 coupe.10:1 331 stroker,holley aluminum heads,lunati 61011 cam,30lb injectors,ported evplorer intake
bunso is offline
post #17 of 17 Old 02-06-2016, 08:09 PM
Decipha's Avatar
DIRECT LINK
http://www.efidynotuning.com/injdata.htm
decipha @ EFIDynoTuning
Decipha is offline
For Sale Siemens Deka 80lb EV1 injectors like new! eric hood Fuel System & Related 1 07-20-2014 08:29 PM
For Sale Siemens Deka 60lb and 80lb injectors autosay97 Fuel System & Related 2 07-20-2013 09:53 PM
Want To Trade Siemens 60lb EV1 plus cash for Siemens 80lb EV1 WV2000GT Fuel System & Related 1 01-02-2013 01:18 PM
For Sale NEW Siemens Deka EV6,EV1 high impedence 80lb injectors 95SC Fuel System & Related 11 10-25-2012 06:18 PM
For Sale Siemens deka 60lb and 80lb injectors, FRPP 42's autosay97 Fuel System & Related 11 01-07-2012 10:25 PM
