why pay 850 when you can pay 700? - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 10 Old 01-27-2015, 07:51 PM Thread Starter
P.i.m.p. vs. Megasquirt plug and play. Why do people pay over 100 more for the megasquirt plug and play when the pimp is the same thing? Am I missing something?
89civichatchback is offline
post #2 of 10 Old 01-27-2015, 08:56 PM
Just my opinion, but the pimp is the only thing I will run on all my non OBII builds from now on!
86 SVO
95 GT
Johnnym1 is offline
post #3 of 10 Old 01-27-2015, 09:24 PM Thread Starter
They are the same thing right? So why pay more for the megasquirt
post #4 of 10 Old 01-27-2015, 11:31 PM
Cantbuyitright's Avatar
Trader Feedback: (56)
Mega can be bought through power adder solutions ( supporting vendor )for 750ish.
Cantbuyitright is offline
post #5 of 10 Old 01-28-2015, 10:11 AM Thread Starter
P.i.m.p is 700 with tuner studio license
post #6 of 10 Old 01-28-2015, 02:54 PM
Both use a MicroSquirt Module at their core, but they use different circuit boards. They also have completely different support teams behind them.
There are a couple areas where I know we did things differently with the MSPNP than Stinger did with the PIMP:
1. PIMP systems are built to order; we maintain a stock of MSPNPs ready for immediate shipping.
2. They handle low impedance injectors differently - the PIMP uses a current limiting resistor, while the MSPNP uses a true peak and hold circuit to pop the injectors open with 4 amps and then drop it back to 1 amp to hold it open once the injector has opened.
3. I believe our knock circuit is more sophisticated, although I'm not sure.
4. The current MSPNP was designed around the A/C idle up code in MS2/Extra 3.3.x firmware. I know the PIMP system predates this and I am not sure if they have updated their design to handle this.
Matt Cramer
Matt Cramer is offline
post #7 of 10 Old 01-28-2015, 07:54 PM Thread Starter
Thanks for the info
post #8 of 10 Old 02-06-2015, 10:28 PM
How can you get it for this price? I've looked online and can't find it. I'm looking to order one ASAP.
TurboVert91 is offline
post #9 of 10 Old 02-22-2015, 10:21 AM
Just Chuck's Avatar
Marketing. PIMP would not be my 1st choice for a product name.
1989 LX 5.0 - 333 Mexican block, Eagle 4340 neutral3.25" crank, Probe SRS 9cc dome .040 psitons AFR 185 Comp heads, FTI HR cam 239/244 613/613, Edelbrock Victor 5.0, 90mm TB, BBK 1 3/4, C4 and 4500 Circle D converter, 4.10 gears
2012 GT/CS 5.0 - Yellow Blaze Tri-Coat metalic, A6, HID.
Just Chuck is offline
post #10 of 10 Old 02-22-2015, 10:24 AM
-Wraith-'s Avatar
Trader Feedback: (29)
Lol yes pimp is such a bad bad name lmao
Just another slow mustang with a single turbo....
-Wraith- is offline
New 5.0 afr185/XE270/RPMII/AOD 3000rpm stall - idles @ 700 RPM with a/c on Enjoy_the_Ride 5.0/5.8 Engine Tech 1 06-30-2014 09:11 AM
For Sale holley ultra hp 850 new 84twinturbo427 Fuel System & Related 0 04-27-2014 01:00 AM
For Sale Kenne bell 2.1 only 700 miles Beatdown Power Adders 23 08-18-2013 04:34 PM
For Sale 850 aed holley edelebrock fuel sys mrpayne Fuel System & Related 0 07-16-2013 07:09 PM
Got a new 700 for christmas. zakk Lounge 15 12-29-2010 02:20 AM
