DOHC cpu - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 3 Old 11-30-2014, 07:53 PM Thread Starter
DOHC cpu
Are there any aftermarket computers that dont require a auxiliary ignition box (MSD). I would like to try something that is complete like the factory unit, however my car was a pushrod changed to mod motor.
Jon
white 95 gts,
old: 331, bordix heads, comp cam, SSI-R manifold, 80mm fox t/b swap, tko600,
got a 5.4dohc, custom cams, ported heads, custom intake manifold, blah, blah blah. tko600 still.
mustangheaven is offline
post #2 of 3 Old 12-02-2014, 01:26 PM
The MS3 can run a modular motor without a separate ignition controller; however, it does need separate ignition modules to use stock Ford coils. These are still under the control of the ECU, so you have a single point of tuning - it's not like running an MSD 6011 where the MSD box controls the timing.
Matt Cramer
Matt Cramer is offline
post #3 of 3 Old 12-04-2014, 05:14 AM
Michael Plummer's Avatar
Trader Feedback: (87)
Jon
Sounds like a pretty cool setup. You could give Pro-M Racing a call and ask about their Pro-M EFI system. They make custom harnesses for any application and the software is very user friendly. Do a search for Pro-M EFI and read about other people's success stories.
849rwhp and 771rwtq SAE
Pro-M Racing EMS
Michael Plummer is offline
For Sale alot of dohc stuff. 96-98 cobra and navi 5.4 dohc blackfalcon62 Modular Engine Parts 19 08-20-2013 12:43 AM
For Sale COBRA DOHC MODULAR PARTS PRICED TO SELL, HEADS, INTAKES, COP VALVE COVERS, ETC Joe46ho Modular Engine Parts 22 02-02-2013 08:56 PM
For Sale Magnesium intake DOHC, Aeromotive fuel rails, Comp Cams Adjustable Cam Gears, Cams wesdearing Modular Engine Parts 6 09-15-2012 08:43 PM
Serious questions dilemma about mechanical oil PSI gauge and DOHC oil PSI readings Cobra Jet NJ GT & SOHC 11 12-14-2001 04:19 PM
5.4L DOHC to be used in production car mkoesel GT & SOHC 16 11-26-2001 03:22 PM
