a9l problem!! - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 2 Old 11-26-2014, 09:31 AM Thread Starter
Angry a9l problem!!
has anyone had a A9L computer just go down !? i looked over my Harness havent found any problems would a alt cause it to fry or maybe some bad grounds i found two ground wire beside the ecu that looks like it runs to the main harness that were a little loose you could move them im wondering if it could cause something also my battery is relocated to the trunk so im going to check all body and block ground what do you guys think?? i did convert the 5 speed car to a built c4 dunno if that would cause a prob or not had been running fine tho!
projectx is offline
post #2 of 2 Old 11-28-2014, 11:48 AM
A little confused by your post. What issues is the car having?
projectstang92 is offline
Misfire problem '96 GT SPLXTREM GT & SOHC 3 12-07-2011 10:54 AM
5.0 intermittent cold start problem (long) EL1XR8 5.0/5.8 Engine Tech 4 10-10-2011 01:57 PM
99 cobra problem, please help!!!!,... please!!!!! spike302 SVT & DOHC 1 09-21-2011 04:51 PM
Air Bag Problem 1992 Mustang GT 1993 Mustang Electrical & Wiring 0 09-14-2011 08:03 AM
Fuel Delivery Problem Solved!! Blown46Cobra GT & SOHC 9 12-18-2001 01:44 PM
