Accufab 4150 TB IAC wiring - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 4 Old 11-17-2014, 04:22 PM Thread Starter
irwinner's Avatar
Trader Feedback: (47)
Ok so I'm buying a 4150 throttle body from accufab and it comes with the GM IAC and TPS. I figured out how to wire in the TPS to the ford harness but I haven't found any solid info on how to wire the 4 wire GM IAC into the ford IAC harness, if it can be done at all. I realize they are two different types of IAC sensors as well. Does anyone have any information on this? I'll be using a megasquirt pnp system. Thanks
306 - RIP - 12.01 @ 117.2....
408w AFR 220, Ported Super Victor, FTI Cam, Holley EFI
irwinner is offline
post #2 of 4 Old 11-18-2014, 09:16 AM
Is that the MSPNP, a DIYPNP, or a regular MegaSquirt with some sort of adapter harness?
Some of these cannot be set up to control the IAC valve; others can, but you'll need to run new wires for it.
Matt Cramer
Matt Cramer is offline
post #3 of 4 Old 11-18-2014, 09:18 AM Thread Starter
irwinner's Avatar
It will be the MSPNP system. So i'll just ditch the IAC, no biggie. I've heard of people tuning around it before. Thanks!
irwinner is offline
post #4 of 4 Old 11-18-2014, 10:06 AM
I'm afraid the MSPNP has no stepper IAC output, as it was designed to work with the stock Ford IAC.
Matt Cramer
iac valve problem 99gt95 GT & SOHC 7 01-31-2013 09:48 AM
For Sale full wiring harness from 90 5.0 vert mygreengt Electronics and Entertainment 2 09-09-2011 08:57 PM
For Sale Detailzone wiring, ecu, etc 4.6dohc teach4.6 Electronics and Entertainment 7 09-09-2011 03:40 PM
For Sale DetailZone wiring and ECU for dohc4.6 teach4.6 Modular Engine Parts 3 09-05-2011 12:51 PM
For Sale Accufab 80mm race TB with spacer and new IAC, etc couperdude Fuel System & Related 7 01-03-2011 01:35 PM
