Sputtering at low rpm wtf is happening - Ford Mustang Forums : Corral.net Mustang Forum
post #1 of 5 Old 11-16-2014, 09:29 PM Thread Starter
First time here so bear with me so I'm just gonna give as much info as I can I bought this car from a dealer I don't know much about it it's sputtering and sometimes pops at low rpm if I mash the throttle runs mint stinks like raw fuel also it has longtubes factory upper and lower 5.0 intakes cleaned up e7s 24lb injectors calibrated bank maf tb spacer bigger springs 255lph fuel pump mad ign. Set up and someone burnt a chip for it WTF is going on
White9031 is offline
post #2 of 5 Old 11-21-2014, 10:09 PM
No answer for you just a bump cause I'm having a similar issue.
Joel27 is offline
post #3 of 5 Old 11-21-2014, 10:45 PM
indy2000's Avatar
redo this post in a coherent manner.
will try to help once I understand what the freck you are saying.
indy2000 is offline
post #4 of 5 Old 11-22-2014, 02:03 AM
Does this help any?
"First time here so bear with me. I'm just gonna give as much info as I can. I bought this car from a dealer and I don't know much about it. The car is sputtering and sometimes pops at low rpm if I mash the throttle it stinks like raw fuel. The car has longtubes headers, factory upper, and lower 5.0 intakes. I've cleaned up the e7s 24lb injectors calibrated bank maf and throttle body spacer.
It also has bigger springs 255lph fuel pump, and msd ign. WTF is going on."
Joel27 is offline
post #5 of 5 Old 11-22-2014, 09:20 AM
indy2000's Avatar
sorta?
start here
put the stock maf and injectors back in, and report.
indy2000 is offline
Car bogs at WOT above 3000 RPM (SOLVED!) KK6695GT 94/95 Tech 31 06-11-2019 03:23 AM
low rpm buck.. superbean 5.0/5.8 Engine Tech 4 06-20-2011 09:48 AM
Runs Rough at low rpm. burtcampbell 94/95 Tech 20 12-22-2004 01:46 AM
Help. Drivetrain shakes fw and bw at low rpm cruise znaut 5.0/5.8 Engine Tech 2 12-17-2001 01:58 PM
